    2000 Trans AM DW2000TA's Avatar
    Tallahassee, FL
    Indigo Blue
    2000 Pontiac Trans AM WS6
    My headlights and dash lights flicker????
    It just started about a week ago when i noticed that my throw out bearing was making noise... any relation? if not what do i do about the flicker?
    Aurora Colorado
    No has nothing to do with a TO bearing. ...I check for tight and clean battery cables 1st to see if this corrects the problem. Look at both ends and cable ground connections as well.
    2001 WS6 Artic White, M6,Procharger D1SC, Custom air box for use of stock filter and location, and ram air function.ATI Superdampner 8 rib drive 540.3Hp 533.8Tq @ 9psi,
    redls1bird
    Guest
    sounds like a voltage problem from the alt. most times its the voltage regulator in the alt, but im not sure if its able to be had seperatley from the alt.
    Senior Member
    Jacksonville, FL
    Mine has always does that when the air pump cycles on cold starts, if it's doing it all the time I'd suspect the alternator.
    Lost in Texas
    Custom Slate Blue
    99 B4C
    Quote Originally Posted by redls1bird
    Nope can't be seperated, yay for internally regulated alternators.
  1. Help! Dash lights off & when headlights on radio lights off
    By BlackWS6TA in forum Firebird / WS6
    Last Post: 07-20-2012, 10:39 AM
  2. Replies: 0
    Last Post: 09-07-2010, 04:25 AM
  3. Help: 2000 Trans am lights flicker!
    By juvie909 in forum Firebird / WS6
    Last Post: 05-08-2009, 07:42 PM
  4. All Lights Flicker
    By vgm in forum Stereo and Electronics
    Last Post: 12-23-2008, 02:05 AM
  5. why do my headlights flicker?
    By ws62002 in forum Firebird / WS6
    Last Post: 01-21-2007, 08:36 AM
