Results 1 to 3 of 3
07-20-2012, 09:40 AM #1Junior Member
- Jul 2012
- Atlanta
Black- 2002 Trans Am
Help! Dash lights off & when headlights on radio lights off
My 2002 TA WS6 last night started acting up while driving home. The lights on the dash just went out and so did the radio lights. The gauges still work as does the radio, I just cant see what station its on. The lights on the steering wheel work, the odometer, and trip counter all still light up. I checked all the fuses (the panel next to the driver on the side of the dash, and the 2 panels under the hood, no blown fuses). The dimmer switch still works because when I adjust it, the lights on the steering wheel adjust from dim to bright.
When the ignition is on and the lights are off, the radio lights up and works, however when I turn the parking lights to on, or to the headlights on position, the radio lights then go off. The dash lights never come on.
What gives? Help!
DanLast edited by BlackWS6TA; 07-20-2012 at 09:47 AM.
07-20-2012, 10:13 AM #2None Shall Pass
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
Sounds like a bad connection to me. Try checking the wire harness plugs, and inspect for loose/broken wires.
07-20-2012, 10:39 AM #3Junior Member
- Jul 2012
- Atlanta
so i have made a little progress. turnes out the dimmer fuse (5A) blew. I replaced the fuse and it blew right away again. I then put a 10A fuse in (dash lit up for a second) and the brake light fuse blew. There isn't any water in the tail lights as far as I can tell. The car did sit in a parking lot and it rained for a few days before I drove it.
Help: Driving lights & parking lights on with headlights down ?
By AZBlackBird in forum Firebird / WS6Replies: 4Last Post: 04-02-2012, 08:48 PM -
'00 with idiot lights but no interior dash lights. Whut?
By Zabo in forum Firebird / WS6Replies: 0Last Post: 09-07-2010, 04:25 AM -
No running lights, dash lights
By 77k5 in forum General HelpReplies: 10Last Post: 01-07-2010, 11:35 AM -
Radio Lights
By maroonZ in forum Stereo and ElectronicsReplies: 4Last Post: 07-28-2006, 10:35 AM -
My headlights and dash lights flicker????
By DW2000TA in forum General HelpReplies: 4Last Post: 01-05-2006, 09:27 AM
