Results 1 to 17 of 17
Thread: All Lights Flicker
12-11-2008, 09:41 AM #1
- Jul 2007
- Long Island
Silver- 1998 Camaro SS
All Lights Flicker
Recently I have been having a problem with my 98 SS. All lighta (headlights, tail lights parking odometer etc) are flickering. I load tested the battery and it came up bad so I got a new battery but that did not fix it. I tested the alternator and it passed with nothing wrong but i do have ac current into the battery. I was wondering if anyone else had this problem and fixed it. An help would be appreciaated. Thank you.
12-11-2008, 10:21 AM #2
- Jan 2006
- Shepherd, Michigan
the tests dont tell the whole story...our alternators are severally under-powered...get either a 99+ truck alternator..i think its 180+amps and swap the plastic backing or go buy a aftermarket ls1 alt. that has higher amps.
12-11-2008, 11:34 AM #3
Do you have a stereo system or no?? I actually had a similar problem with the alternator, no stereo system. I replaced the alternator and it hasn't done it since.
2000 Camaro SS, M6, Edelbrock LT's, Eibach Pro-Kit, Edelbrock Adjustable Coil-Overs
1986 Camaro Iroc LS1 Swap In Progress
Blue Magic...
Like Pepsi It's A Brand Name...
12-11-2008, 11:55 AM #4
- Jul 2005
- Jacksonville, FL
Is it continuous or only on cold starts? Could also be the air pump cycling.
12-11-2008, 12:21 PM #5
- Jul 2007
- Long Island
No stereo system, aftermarket head unit and i replaced the two door speakers because they were blown along with all the other speakers in the car (they were when i got it) but those were all the stock ones. And its continuous happens non stop even if my headlights are off the odometer still does it.
12-11-2008, 12:24 PM #6
It could be that the alternator can't handle the load... did you have it load tested.... like I said I had the same problem...
12-11-2008, 12:25 PM #7
- Jul 2007
- Long Island
Yeah i had it load tested it passed with no problems so im kind of afraid to throw an alternator at it before im positive.
12-11-2008, 01:28 PM #8
- Feb 2006
- Orange County, NY
I would check all connections at the battery, starter and alternator. Look at all ground connections too. I think there is a fuse under the hood for all lighting. I would check and make sure there is no corrosion there either.
12-11-2008, 05:46 PM #9
- Jul 2007
- Long Island
Okay i seemed tp have narrowed it down to being the alternator. Would someone be able tp tell me what the stock amperage is and if i should get a higher one or just go oem or if theres a upgraded oem?
12-11-2008, 06:02 PM #10
sounds like a bad ground to me if your alt isnt bad
12-11-2008, 06:09 PM #11
- Jul 2007
- Long Island
Well i checked the grounds under the hood and main ground on the block and they were good. Could i be missing any?
12-12-2008, 07:57 AM #12
12-12-2008, 08:34 AM #13
- Feb 2006
- Orange County, NY
A stock alternator is fine if you dont have any extra accesories on the car.
12-12-2008, 09:22 AM #14
- Jan 2006
no it really isn't...there was a recent service bulletin talking about the amount of amps certain options and accessories pull..with all the options on my trans am....that is headlights,fog lamps, air pump, heater, fan...it left me with 5 amps to spare...and that is without the radio. now for your lt1...it is fine since your at i believe 145amps compared to ls1's 105amps.. late fourth gen f-bods need a 140+
12-12-2008, 02:14 PM #15
- Jul 2007
- Long Island
Okay thanks guys il look into it and pick one up.
12-21-2008, 02:35 PM #16
I have recently had this problem.Turned out to be the connection at the alt. The easy way to check is to unplug your alt and start the car and see if your lights still flicker.If they do your problem is somewhere else.
12-23-2008, 02:05 AM #17
- Oct 2005
- San Antonio
Silver & Black- 99 Camaro SS
I posted a test in another thread on alternator noise in the sound system. Again, hook up chargers and/or another car (jumped). You can isolate more surely to it being the alternator or its connections.
Also, was the alternator tested out of the car? If it was you are almost certainly talking about a connection being the problem.
But this could well be a combination problem, an alt getting old and a little tired and a connection that is getting more and more resistive. I hate to get to that point...but if you drive it long enough and it is a connection, you can feel the heat at the connector to blame!
Help: 2000 Trans am lights flicker!
By juvie909 in forum Firebird / WS6Replies: 18Last Post: 05-08-2009, 07:42 PM -
Tinted Turn Signals, Rear Lights, Bumper Lights
By BADASS2000SS in forum Camaro / SSReplies: 24Last Post: 02-19-2009, 01:10 AM -
Random noise/headlight flicker
By jayjayta in forum Camaro / SSReplies: 2Last Post: 10-04-2008, 08:45 AM -
why do my headlights flicker?
By ws62002 in forum Firebird / WS6Replies: 19Last Post: 01-21-2007, 08:36 AM -
My headlights and dash lights flicker????
By DW2000TA in forum General HelpReplies: 4Last Post: 01-05-2006, 09:27 AM
