Results 1 to 19 of 19
Thread: 2000 Trans am lights flicker!
04-29-2009, 10:17 PM #1
Has anyone resolved the problem with their trans am headlights flickering? If so how did you get it done?
04-30-2009, 12:02 AM #2
- Columbia,SC
Millienum Yellow- 2003 Corvette Z06
going ot ask the obvious but have you checked the connection to the back of the light? Might have come loose??
04-30-2009, 01:15 AM #3
- Dec 2005
- Laurel, Maryland
Is it all of your lights or just the headlights?...it could be your alternator going bad.
04-30-2009, 03:47 AM #4
- Oct 2007
- Beaver Dam KY
Alternator/Air Pump cycling.
Here is an example of my air pump cycling before i deleted all my emissions... its near the end I think...
04-30-2009, 07:51 PM #5
- May 2008
- Dallas
Black- 99 trans am
i have the same problems with my headlights and taillights
04-30-2009, 08:57 PM #6
alternator GM made the mistake of puttin the alternator under (not on top) when u catch a bad storm alt is easy to get wet everytime, sooner get dry but messes with the regulator the only way 2 fix this is buyin the whole alternator or maybe a rubber cover will help protect the alternator from watet...but then again it may get too hot and faulty
04-30-2009, 09:30 PM #7
funny you say that, my pass side headlight flickers. I only notice it at night time on signs and in peoples back windows and stuff. I tried to see if i could tighten something up but the joint on the bracket (rivet) that pivots the light up and down is loose. Probably more annoying to people that im driving behind at night. probably unrelated but thats my issue.
04-30-2009, 10:11 PM #8
05-01-2009, 01:31 PM #9
I got the same problem I think I might try to buy the alternator relocation kit that gets rid of the tensioner
05-01-2009, 08:18 PM #10
05-01-2009, 10:29 PM #11
headlights and dashboard and taillights.
My headlights and dashboard and taillights all do the same thing. Also my voltage meter on my dashboard flickers from 12 volts to 8 or 10. Any ideas? how much is a new alt?
05-02-2009, 07:36 AM #12
- Oct 2007
- Beaver Dam KY
05-02-2009, 09:08 AM #13
05-02-2009, 12:45 PM #14
- Oct 2007
- Beaver Dam KY
05-03-2009, 04:34 PM #15
- Nov 2008
- Warner Robins, ga
red- 2002 Trans Am
It is possible that your electrical system could have an intermittent high draw condition, loose connection or a bad battery. When I worked at AZ we would see this problem occasionally...sometimes the side terminals on the battery would be bad...sometimes the the plates in the battery would short and you could have an issue with the distribution panel on the driver's side of the car or bad connection at the alternator. Check your connection at the alternator thoroughly...look for brittle or discolored wiring. If it is bad solder in your new pigtail assy DO NOT CRIMP CONNECT.
Hope it works out!
05-04-2009, 06:57 PM #16
05-04-2009, 07:38 PM #17
i replaced the batt with an optima batt so i narrowed that out. but i still havent replaced the alt. Also has anyone had a problem with their horn. mine never goes off?
05-04-2009, 08:27 PM #18
05-08-2009, 07:42 PM #19
- Nov 2008
- Warner Robins, ga
red- 2002 Trans Am
What do you mean by "mine never goes off"? When you push the pad? Set the alarm? I had a problem with my low note horn filling up with water every time it rained. The high note horn was on the bottom and pointed down while the low note was pointed up. I replaced the horn and swiveled it on the bracket as far as the harness would let me to point it down too....problem solved.
Question: 2000 WS-6 HID Lights
By Taurian00 in forum Firebird / WS6Replies: 13Last Post: 03-12-2010, 03:40 AM -
All Lights Flicker
By vgm in forum Stereo and ElectronicsReplies: 16Last Post: 12-23-2008, 02:05 AM -
why do my headlights flicker?
By ws62002 in forum Firebird / WS6Replies: 19Last Post: 01-21-2007, 08:36 AM -
abs/ tcs lights always on 2000 GTP
By ksenzee in forum Computer & TuningReplies: 4Last Post: 09-20-2006, 04:57 PM -
My headlights and dash lights flicker????
By DW2000TA in forum General HelpReplies: 4Last Post: 01-05-2006, 09:27 AM
