Results 1 to 3 of 3
07-20-2008, 02:49 PM #1
Ride height question QA1r's and V6 springs
I'm curious what you guys cars ride height is. I have BMR lowering springs on the rear with my QA1r's up front lowered. It was slammed pretty good front and back. We l just got thru removing the rear BMR springs that were to stiff for the track and replaced them with some V6 springs and comp engineering shocks set at 50/50. Wow now I'm riding high unless Im in shock because what I was use to. My measurements are
28.5 rear drivers
28 rear pass
27 front drivers
26.5 front pass
I just raised my front up half inch to balance it out some. Does this sound right for a V6 springs in the rear and QA1's up front.
07-21-2008, 04:23 PM #2
Every car is different depending on tire size and load. Just cut a 1/4 coil out of the V-6 springs at a time until you get it to the lowered height you want. We usually cut around 3/4-1 coil for car that has 1.5"-2" drop in the front. Remember to fill the tank up and we usually even take some eight and put it in the drivers seat to mock up the real weight.
07-21-2008, 05:17 PM #3
I think its just me right now. I'm use to the BMR's. I put these in for the drag strip only. I might just put my WS6 springs back in also and see how they compare at the track after I run this weekend with these V6 springs. I know the BMR's cant be helping me at the track with my rotten 2.1 60 ft.
What is normal ride height???
By Whamhammer in forum Suspension and HandlingReplies: 2Last Post: 05-21-2016, 02:25 PM -
By Dr.Crash in forum Suspension and HandlingReplies: 3Last Post: 06-29-2008, 12:18 AM -
ride height?
By Dr.Crash in forum Suspension and HandlingReplies: 8Last Post: 09-11-2007, 11:02 AM -
Stock ride height?
By UKXK189 in forum Suspension and HandlingReplies: 1Last Post: 07-26-2007, 01:14 PM -
Pinion angle for an adjustible TA on a stock height ride?
By NeeD4SpeeD in forum Suspension and HandlingReplies: 4Last Post: 01-31-2006, 01:23 PM
