    Senior Member NeeD4SpeeD's Avatar
    New York, NY
    Collectors Edition Yellow
    2002 Pontiac Trans AM WS6
    Pinion angle for an adjustible TA on a stock height ride?
    I know that i need to set the pinion angle to -2 on the adj TA for stock height apps. but how do i know that it's at -2??? Is there away of measureing it or telling???
    The TA is a BMR Adj. TA....
    Senior Member ninobrn99's Avatar
    Aug 2003
    Honolulu HI
    all bore 370 Trans Am
    i pull the DS and put the protractor on the tailshaft, get the angle, then get set it on the pinion nut and get that angle. do the math and adjust the large nut on the bottom of the torque arm. - the rearend faced down + it faces up.
    Moo cow f**k milk Demon_Speeding's Avatar
    New Mexico...from Kansas City
    2001 Camaro Z28
    From the instructions I got with my Spohn T/A you need to measure the angle of the driveshaft, then measure the angle of the pinion. I got my pinion measurement on the bottom pad of the T/A. If I remember correctly you subtract the DS angle from the pinion angle to find the true pinion angle, then adjust accordingly.
    Aug 2003
    Honolulu HI
    people will argue which way is right. i just chose to go about it the way i do because plenty of shops and people on the forums suggested that i do. otherwise id have done it like you did.
    New York, NY
    Thx 4 the info i gotta do it when i finish installing it... Then we'll c how it comes out...
  1. Pinion Angle
    By pajeff02 in forum Drivetrain
    Last Post: 04-05-2010, 08:45 AM
  2. Stock ride height?
    By UKXK189 in forum Suspension and Handling
    Last Post: 07-26-2007, 01:14 PM
  3. Pinion Angle Gauge SE WI
    By 2kbluws6 in forum Mid-West Members
    Last Post: 05-29-2007, 07:09 AM
  4. pinion angle help please
    By shawn2002z28 in forum Drivetrain
    Last Post: 04-10-2006, 01:58 PM
  5. Help with pinion angle
    By JGA in forum Suspension and Handling
    Last Post: 10-15-2005, 04:56 PM
