Thread: Pinion Angle
    Pinion Angle
    I just want to make sure I did this correctly. With the car on its wheels and the suspension settled (bounced the car a few times and let it sit for a bit) I used a digital level on the driveshaft and the bottom plate on my torque arm at the differential. The driveshaft points down 2.4 degrees, so -2.4. The rear points up 0.9 degrees after adjustment, so +0.9. Adding the two numbers yields negative 1.5 degrees. Did I do that right?
    (Like Iroc, I gotz MSPaint skilz!)
    May 2008
    Line Lexington, PA
    2002 z28 camaro
    From everything that I have read, Yes you did.....but I would like a confirmation from someone else too
    Member Blue Thunder 42's Avatar
    Crownsville MD
    98 SS Camaro
    That's what the directions said with my BMR adj TA.
    Member Supershafts's Avatar
    Apr 2010
    Long Island, N.Y.
    1971, 73,78, 85,92,95,
    If your shaft is running 2.5 at the pinion, then you want the pinion at/between +.5 to +1.
    Then when you are under load it will probably take out another 1. (tq arm equipped) and be close to 0 which is the non hp robbing angle you want.
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    That is how I understand it also Jeff. As mentioned above, under load, theoretically you want the angle to be 0 degrees. Most common is set at about -2 from what I've read.
    Here is some more info about it. http://www.carcraft.com/howto/91758/index.html
    Thanks Jon! This thread had not received many responses and I wanted some assurance that I did it right. I subscribe to Car Craft, but that article you linked was published too long ago for me to remember it.
    Apr 2010
    Long Island, N.Y.
    You did it right.
    2 degrees is the safe standard.
    When tq arms are added or link style or ladder style depending on bushing deflection you could take some more out.
    Some 4 links and similar suspensions can dial in less maybe 1. or .05 with solid links
    I don't have much experience with the tq arm gm's to say you could take some more angle away.
    But that is right just like you have it.
    I deal with this everyday if it makes you feel better.
    Quote Originally Posted by Supershafts View Post
    You did it right.
    Thanks! Always good to have confirmation.
  1. Question: whats your pinion angle set at?
    By bpopham22 in forum Suspension and Handling
    Last Post: 02-09-2011, 01:58 PM
  2. need a pinion angle finder
    By sic2001 in forum Parts Wanted / Trade
    Last Post: 02-01-2008, 09:05 PM
  3. question about pinion angle?
    By TASWEET SS in forum Suspension and Handling
    Last Post: 05-07-2007, 08:15 AM
  4. pinion angle help please
    By shawn2002z28 in forum Drivetrain
    Last Post: 04-10-2006, 01:58 PM
  5. Help with pinion angle
    By JGA in forum Suspension and Handling
    Last Post: 10-15-2005, 04:56 PM
