Thread: question about pinion angle?
05-07-2007, 05:42 AM #1NATRALLY ASPIRATED 495 HP
- Jan 2007
- chesapeake, VA. DEEP CREEK
pull me over RED- 2002 camaro SS
say you have adj. lower control arms and stock tq.arm can you move the pinion angle + or - ? next question, what is stock pinion angle? next question,say you have adj.lca and adj. tq arm what degree(-2) would you set it at if you went drag racing? what would you keep it at on the street? just trying to learn ya know!
05-07-2007, 06:21 AM #2Just me
- Nov 2006
- Broken Arrow, OK
Stock pinion angle is -2 I believe.
Having adjustable lower control arms enables you to move the rearend front to back or vice versa, it doesn't change the pinion angle. The only way to adjust the pinion angle is by having an adjustable torque arm I think.
Read this thread here to answer your question on the setting for drag racing.
05-07-2007, 08:04 AM #3NATRALLY ASPIRATED 495 HP
- Jan 2007
i agree, to center up your wheel in wheel well, i think you need adj.lca and adj. tq. arm for the pa
05-07-2007, 08:15 AM #4
Pinion Angle question
By SajoR in forum Suspension and HandlingReplies: 5Last Post: 01-19-2011, 10:45 AM -
Pinion angle question for a math idiot
By bberretta in forum Suspension and HandlingReplies: 19Last Post: 01-13-2011, 12:10 PM -
Pinion Angle
By pajeff02 in forum DrivetrainReplies: 7Last Post: 04-05-2010, 08:45 AM -
pinion angle question
By Ratdaddy07 in forum DrivetrainReplies: 4Last Post: 11-03-2007, 01:05 AM -
Help with pinion angle
By JGA in forum Suspension and HandlingReplies: 0Last Post: 10-15-2005, 04:56 PM
