Results 1 to 14 of 14
04-01-2006, 10:52 AM #1
setting proper u-joint and pinion angle
Pinion Angle
Tired of breaking cases and drive shafts? There are many books that misled you on setting the pinion angle. For Drag Racing this is simple. You are trying to set the pinion angle to be parallel with the centerline of the engine & transmission on hard acceleration. To achieve this you must first figure out the parallel setting of the rear end to correspond to the angle of the engine & transmission, then add the proper amount of pinion angle. Add 1 deg. for 4-Link vehicles, 2 to 3 deg. for ladder-bar vehicles. Place stands under suspension to duplicate vehicle at ride height. Caution do not remove drive shaft without securing vehicle first. Take measurement with drive shaft removed. (shown below)
Operating Angle
Operating angles in a driveshaft are the angles between the pinion, driveshaft and transmission centerlines. The optimal angle for any driveshaft to run at is 0 degrees, where many vibrational and frictional problems are non-existent. In order to minimize power loss and vibration in an offset configuration, the pinion centerline and the transmission centerline need to be parallel. In general, the largest angle for racing applications should be 2 degrees and the centerlines should be parallel within 1/2 degree. If the centerlines are off too far, the u-joints travel at different speeds causing vibration (this is the same problem induced by poorly phased end yokes). This vibration is hard to distinguish from an unbalanced driveshaft.
05-19-2006, 05:09 PM #2Junior Member
- Apr 2006
- concord, nh
metallic blue- 2001 Z28
Just installed S&W sub frame connectors w/adjustable torque arm. The car now has a strong vibration,especially at highway speeds.Would you expect this to be an incorrect pinion angle condition or normal driveline vibrations being transmitted into the car by the floorpan mounting of the subframe connectors? The S&W adjustable torque arm bolts to the sub frame connector cross member, not in the factory location on the side of the transmission. New Moser 9". No vibrations prior to install.
05-19-2006, 06:35 PM #3
assuming the u-joint angle is within the 2* as described, then yes you are getting vibrations through the SFCs.
06-06-2006, 07:08 PM #4Junior Member
- Apr 2006
- concord, nh
I've been checking out some of the previous threads relating to setting of the pinion angle. There were some pretty strong opinions expressed. I'm still having the same vibration problems but trying to work it out. I found a website that includes layman language,clear instructions,photographs and examples- vibratesoftware com. Then click on "Propshaft Angle Correction Calculator". Unfortunately, you will have to use a Kent-Moore Driveshaft Inclinometer to use the procedures described. Assuming I will eventually solve the mystery of the vibrating Camaro can it be expected that the stock aluminum driveshaft w/Spicer 1310 U-joints in front and 1350's in back(Moser 9", 4.11's, Detroit Tru-Trac and T-56) and 473 rwhp and 491 rwtq through the muffler(THANK YOU EAST SIDE PERFORMANCE!) will survive w/M/T ET Streets and an expected 4000 launch RPM?
11-19-2006, 11:47 AM #5
11-20-2006, 12:00 PM #6Junior Member
- Apr 2006
- concord, nh
Setting proper u-joint and pinion angle
Hey Orange-thank you for your insight. Never did test the theory of the aluminum driveshaft. Went with a steel shaft and Spicer 1350"s. Ran all season with no problems(4500 launch RPM w/12 psi). I ordered the Kent-Moore Driveshaft Inclinometer. Took 3 months to get. Very disappointed. For $150 I expected more. Figured I could better so that's what I'm going to do. I'll post pic's when done. Had a a very satisfying season. Best time 11.15 @ 122 through the exhaust. Now I have to get a roll bar! Going to work on the chassis/suspension this winter to improve 60'- best 1.62. Might be able to get into the ten's. Pretty remarkable for a stock appearing vehicle I can drive on the highway with the a/c on and over 20 MPG. Got to love the LS1!
11-20-2006, 12:22 PM #7
01-10-2007, 05:06 PM #8
03-18-2007, 11:15 PM #9
There is another trick to measuring your angle now WITHOUT removing the driveshaft let alone jacking up the car.
Put car in nuetral lay down on the ground roll tire with hand until u joint cap is pointing straight up and down. Now place a 5/8 OR 11/16 DEEP socket across face of u joint cap. MAKE sure it's sitting flush on cap NOT on retainer clip.
Now place guage across the face of the socket.
This is how we measure at the track and do adjustments in the stagging lanes. I've found over the years that 3-3.5 works great on 70% of cars and 4 or more degrees just wastes u joints regaurdless of suspension type.
Thats my 2 cents take it or leave it......Don't be afraid of the bottle!!! Be afraid of your tune!!!
04-17-2007, 11:13 AM #10Junior Member
- Oct 2005
- Houston
Sebring Silver- 98 Z28
the pontiac place!! i went to the chevy place to get my stock lca bushings (since then replaced with boxed units)replaced and they said no way jose' the car was too modified. they also said they would not do the rack or the rear end work again....i have a torque arm to replace the factory bent one and blown bushing, rear shocks and subframes. those 3 things on the suspension voided my warranty. damn now i have to get a 9 inch. good luck on the drive shaft /ujoint but they will prolly tell you to get bent
06-22-2008, 09:11 AM #11
05-19-2009, 05:51 PM #12
Also if you lower your car more than 1" you should also correct the pinion angle or is that bogus information ? Just checking .
05-19-2009, 06:19 PM #13
09-19-2009, 05:50 PM #14Junior Member
- Oct 2008
- Cary, NC
Pewter- 2000 Pontiac Trans am M6
helped me out alot thanks
Proper u-joint for factory LS1 aluminum ds and moser 9 in
By 99RedTa6spd in forum DrivetrainReplies: 11Last Post: 05-07-2015, 03:06 AM -
setting pinion angle
By ls14gezr in forum DrivetrainReplies: 1Last Post: 02-10-2007, 06:04 PM -
how to set proper and u-joint and pinion angle
By mrr23 in forum DrivetrainReplies: 0Last Post: 04-01-2006, 10:44 AM -
Setting Pinion Angle
By T/Aboo in forum Suspension and HandlingReplies: 1Last Post: 02-08-2006, 02:31 PM -
Pinion angle setting for spohn torqe arm
By sparkey in forum Suspension and HandlingReplies: 3Last Post: 11-17-2005, 09:02 PM
