Results 1 to 2 of 2
Thread: Setting Pinion Angle
02-07-2006, 02:44 PM #1Junior Member
- Jan 2006
- New Orleans, LA
Red- '01 Trans Am WS.6
I've seen the desired pinion angle expressed in two different ways for an '01 T/A; either as (-2) degrees or (+2) degrees. I'm assuming that we want the pinion at an inclined position (tilted upward) in relationship to the drive shaft. Is this correct? And, is this referred to as a (+) of (-) angle?
02-08-2006, 02:31 PM #2
no, you want the pinion to be downward from the driveshaft. that would be in the negative arragement. that way, when you accelerate, the pinion tries to climb up the ring gear. this will make for a 0* angle when accelerating.
setting proper u-joint and pinion angle
By mrr23 in forum Suspension and HandlingReplies: 13Last Post: 09-19-2009, 05:50 PM -
setting pinion angle
By ls14gezr in forum DrivetrainReplies: 1Last Post: 02-10-2007, 06:04 PM -
pinion angle help please
By shawn2002z28 in forum DrivetrainReplies: 22Last Post: 04-10-2006, 01:58 PM -
Pinion angle setting for spohn torqe arm
By sparkey in forum Suspension and HandlingReplies: 3Last Post: 11-17-2005, 09:02 PM -
Help with pinion angle
By JGA in forum Suspension and HandlingReplies: 0Last Post: 10-15-2005, 04:56 PM
