    TJEA Retirement Home Dr.Crash's Avatar
    Feb 2006
    U. S And A Greatest country in all of world
    Stock
    2002 Camaro
    Ride height question
    i have an 02 SS with the 1LE package. about 4 or 5 moths ago my brakes went out and i slamed into a curb. i ended up having to get a new upper and lower a-arm and new bushings. the dealer wanted 1700.00 for it. so i did it my self and only spent 1400.00 plus labor. but instead of stock parts i ended up with BMR tubular K-member, and a-arms with all new bushings. the problem i have now is that my car sits about 1-2 inches higher than it did before the crash. is it something i did? how can i fix it. i have been thinking about getting it lowered but i dont wanna mess with the springs because then it wouldnt be the whole 1LE package anymore. what should i do? Thanks in advance for any help or advice.
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    did you get it aligned?
    Jesus died to save you! Killer_bluebird's Avatar
    North Olmsted, OH
    Did you get new springs and shocks or did you re-used them?
    I'm (Hurst) Equipped... davebowtie's Avatar
    Santa Barbara County,Ca.
    Onyx Black
    '02 Camaro SS(replica) M6
    Did u install these parts yourself? If so did you make sure NOT to fully tighten your control arm bolts until the car is sitting on the ground under all of it's own weight? this may be the problem, the a-arm bushings are probably binding and not letting the suspension sit correctly. I hope I'm not to late with this comment or maybe u fixed it already???
    C:\Documents and Settings\Dave\Desktop\sig01.jpg
  1. What is normal ride height???
    By Whamhammer in forum Suspension and Handling
    Last Post: 05-21-2016, 02:25 PM
  2. Ride height question QA1r's and V6 springs
    By 01WS6475hp in forum Drag Racing
    Last Post: 07-21-2008, 05:17 PM
  3. ride height?
    By Dr.Crash in forum Suspension and Handling
    Last Post: 09-11-2007, 11:02 AM
  4. Stock ride height?
    By UKXK189 in forum Suspension and Handling
    Last Post: 07-26-2007, 01:14 PM
  5. Pinion angle for an adjustible TA on a stock height ride?
    By NeeD4SpeeD in forum Suspension and Handling
    Last Post: 01-31-2006, 01:23 PM
