Results 1 to 3 of 3
Thread: What is normal ride height???
05-21-2016, 08:03 AM #1Senior Member
- Sep 2010
- Bel Air, Maryland
Silver- '02 Trans Am WS-6, 6M
My front end sits decidedly lower than the rear does. With the car at a slight incline (nose pointing upwards), and 285/40/17s (26.1 tall tire), the fronts are 27.00inches and the rears are sitting at 28.00 measured at the centerpoint of the wheel and wheel arch. Does this seem a bit low?
05-21-2016, 10:42 AM #2
Doesn't seem too low to me considering I sit at 26" front and back with 275/40/17's all around ! Also, you say your front sits lower but then say nose pointing upwards so that's a little confusing unless I'm missing something. My tires sit at 25" tall and I have a 1" gap tire to fender arch. I have Eibach lowering springs that gave me about an 1 1/4" drop. Don't know if that helps -- you sound about stock height to me.
'02 Black RamAir M6--Kooks LTH, Magnaflo, Lowered Eibach springs and Bilstien shocks, Tuned By Frost, K&N & SLP box, Smooth bellows, polished TB, Spohn perf. suspension, shock tower brace. UMI 3point SFC. Front & side splitters w/ canards. American Racing 18" wheels & Mich. Pilot SS titres
'76 LagunaS3 - 355ci , 350 turbo, 3:55's
05-21-2016, 02:25 PM #3Senior Member
- Sep 2010
- Bel Air, Maryland
When I said the nose was sitting up, thats because the car is sitting at an incline, with the front of the car facing upwards on the incline and the back facing down the incline. I would think the weight distribution, based on the incline, the bias would be pushing rearward.
Most 275/40/17's are usually 25.7'ish , where the 285/40/17's are 26.1'Ish. I could see it if the front was facing downward. I also run snow tires in the winter that are about 25.7ish too ( which would drop the front to 26.5ish.
My LT headers/Y pipe drag the ground on all but the smallest speedbumps, and honestly the ride has been getting harsher, I am figuring the springs are starting to weaken, the car is almost at 150k miles now.
Ride height change with bigger wheels/tire
By finkle745 in forum Wheels and TiresReplies: 17Last Post: 08-15-2016, 11:59 AM -
Ride height question QA1r's and V6 springs
By 01WS6475hp in forum Drag RacingReplies: 2Last Post: 07-21-2008, 05:17 PM -
By Dr.Crash in forum Suspension and HandlingReplies: 3Last Post: 06-29-2008, 12:18 AM -
ride height?
By Dr.Crash in forum Suspension and HandlingReplies: 8Last Post: 09-11-2007, 11:02 AM -
Stock ride height?
By UKXK189 in forum Suspension and HandlingReplies: 1Last Post: 07-26-2007, 01:14 PM
