Results 1 to 18 of 18
    Junior Member finkle745's Avatar
    Jul 2014
    Michigan
    Sebring Silver
    1998 Z28
    Ride height change with bigger wheels/tire
    Would I expect a huge change in my ride height changing from the stock 16" to 18 or 19" wheels? I realize the rubber will be thinner, but I want better looking wheels without drasticlly changing the ride height. Is lowering the car the way to go? If so how much $$ we talking?
    Overall you can use 18's all around but depending on tire size. 19's forget it up front and in the back you're looking at doing some minitubs. Even then not sure if you can squeeze 19's plus tires in there, being the body frame rail will be the limiting factor, not to mention the wagon wheel look looks like ass . Also increasing the rotating mass (the wheel) will greatly effect the rear. The POS 10 bolt is easy to blow up so you need to consider that as well.
    I know several members on here that run for 305's and even a few 315's.
    I current have 17x9 Snowflake wills with 255/45/17's on the front & 275/45/17's on the rear. Even with 1" drop springs it only changed my ride height by a 1/2" Now that I have an 8.8 rear and some other suspension mods the rear is a full inch higher than the front.
    I would serious look at the road conditions in MI before trying to lower it. Speed bumps are a task for me.
    Jul 2014
    Michigan
    Sebring Silver
    1998 Z28
    Excellent, thanks for the insight. I'll be taking some serious consideration. It's not a daily driver for me, I just want it to look bad ass.
    Apr 2010
    Alabama
    Black/ Silver
    98 TA WS6/ 01 C5 Corvette
    You can put 19s all around no problem I had 20s with no issues. The sidewall just needs to be smaller in order to not have rubbing unless you want to roll the fenders. I now have 18s now which I like better. A lot of what will fit comes down to having the proper offset.
    1998 Trans Am WS6 - Phantom
    421 LQ9 14.8:1 on E85 Build/
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    original tire size is 245/50-16 which is 25.7" tall. going to a 245/40-18 or 275/35-18 would be 25.6" tall. going to a 245/35-19 would be 25.7" tall. so no height change at all.
    here's my 00 formula with C6 wheels.
    C6 Silver Wheels
    18" x 8.5" with 245/45-18
    19" x 10" with 275/35-19
    Feb 2015
    United States
    Inferno Orange
    2010 Camaro 2SS/RS L99
    Definitely looks to have lifted the car a notch but not too bad. Must just be an illusion. Lowering it an inch to inch and a half would really look nice imo. Could also just be the angle of the picture though.
    Member hardtrailz's Avatar
    Jul 2016
    SE IN
    Blue Green Chameleon
    2001 Trans Am Vert
    C6 Silver Wheels
    Any issue rubbing up front with the taller tires? I a looking at same rim n tire sizes
    2001 Trans Am Vert
    Jul 2016
    SE IN
    2001 Trans Am Vert
    For reference....245 45 18 on 18x8.5 had no rubbing issues anywhere for me so far.
    Mar 2011
    fort myers,fl
    1998 trans am convertible
    98transamws6 and smws6ta. you both seem to be driving the same car. why the difference of opinion?
    Greensboro, NC
    2002 Trans Am WS6 M6
    These cars came with so many different suspension setups stock and then you start adding in the fact many of us are running aftermarket rears and suspension we all get different results with different setups. Hell then you add in TA vs Camaro setups and it makes it that much more fun. Even though they are the same platform a TA can fit wider wheels and tires easier.
    Senior Member Naaman's Avatar
    Mar 2010
    AZ
    Cayanne
    98 Z28 Vert M6
    Another thing to consider would be that even if the ride height changes in relation to the ground, the wheel well clearance probably won't (or it will get smaller, not larger). This, I think, is one of the primary reasons people lower their cars: to reduce the wheel well gap. OP, if you're actually worried about the ride height (for suspension geometry reasons???), then it will only change appreciably if you use a similar profile of tire. The total height of the tire will dictate how far off the ground your axle is, regardless of the height of the wheel.
    Last I checked, more ground clearance was only a good thing... or are you worried about center of gravity issues?
    Quote Originally Posted by DADCRUISER View Post
    What Will is saying is you can go bigger, it just means the tire needs to be smaller. It is possible to have a larger wheel and smaller tire than stock and be at or below the OEM wheel/tire height.
    For example...(these are not exact numbers just showing what I mean)
    OEM 16" wheel with 245/R16/60 would be say 27" tall.
    Now using a 17" wheel with 255/R17/45 would be say 26" tall.
    Or in Will's case - 18" with 255R18/40 would be say 27.5" tall.
    See what I mean?
    Here is a quick way to figure the height of tires & wheels:
    The first set of numbers are the width of the tire, the 2nd is the wheel size and the 3rd is the height of the tire from the inside edge to the top of the tread. It is a percentage of the width of the tire. 255mm*45% = 114.75mm Now convert that last number to in 4.5". Now take the (4.5"*2) + wheel size in this case 17" = 26" of height.
    Here's another example: 290mm*40% = 116mm (4.55") (4.55"*2) + 18 = 27.1" tall wheel/tire
    OEM - 245mm * 60% = 147 (5.7") (5.7*2) + 16 = 27.5" tall wheel/tire.
    Wow I was very close in my hypothetical above.
    Jul 2016
    SE IN
    2001 Trans Am Vert
    Direct example of what i did. Car came with 225 55 16 tires which are 25.74 inches tall
    Seen here:
    and here:
    Went up to a 245 45 18 which is 26.68 inches tall. Nearly a full inch more diameter.
    Seen Here
    and here:
    And here:
    Definitely filled the wheel-wells more and the half inch more ground clearance is really not noticeable IMO. With stock suspension I have no rubbing issues and have good ground clearance and a fuller looking fender gap.
    But had i gone with a 245-40-18 I would have kept the same ride height and the same fender gaps. since those are same diameter as stock
    Mar 2011
    fort myers,fl
    DOES tire height change speedometer accuracy. seem to remember my 73 mustang speedo was affected when i changed to keystone mags and ta 50's. when finished with current changes it will be time for new rims and tires. not much of a racer but do have a heavy foot.
    A little. But the speedo is now programmable in the ecm. When I switch to 4.1 gears my tuner was able to calibrate the speedo on the dyno. It is accurate to at least 100mph.
    It even matches dead on with my gps.
    Gears are the biggest factor in the speedo, tire height not so much as long as you are with in 1-2" of the OEM size.
    Jul 2016
    SE IN
    2001 Trans Am Vert
    https://www.tacomaworld.com/tirecalc...0r16-245-45r18
    Best place I have found for the difference when changing tire sizes. I know my difference in speed currently, but will be getting the speedo corrected with the tune.
    My 1 inch change is certainly off enough to get me a ticket, so I would say it is important.
    Also remember it effectively changes your diff ratio with the diameter change.
    Mar 2011
    fort myers,fl
    THANKS. didn't know about diff change.
    Jul 2016
    SE IN
    2001 Trans Am Vert
    Neither gear or tire size is more important. It is getting them to dial in together. For example my offroad toy has 6 inch oversized tires but lower gears and is basically dead on with the factory effective ratios. It all works in concert and if you play around with a calculator like this you can find the optimal setup for what you want---whether mpg or off the line or a balanced middle ground.
    Speed Potential Calculator For Ring Gear And Pinion Changes
  1. What is normal ride height???
    By Whamhammer in forum Suspension and Handling
    Last Post: 05-21-2016, 02:25 PM
  2. Bigger Tire Sizes On Stock Wheels
    By Alwyn the Wolf in forum Firebird / WS6
    Last Post: 04-07-2015, 04:52 PM
  3. Ride height question
    By Dr.Crash in forum Suspension and Handling
    Last Post: 06-29-2008, 12:18 AM
  4. ride height?
    Last Post: 09-11-2007, 11:02 AM
  5. Stock ride height?
    By UKXK189 in forum Suspension and Handling
    Last Post: 07-26-2007, 01:14 PM
