    Henryetta/Tulsa Oklahoma
    2016 Camaro SS - Summit
    2001 Trans Am WS6 - NBM
    Noise and oil pressure issues. 2000 SS
    Ok, let's see if I can describe this. When I start my car in the morning, or after it has sat for a while, I hear this ungodly constant whine in my engine...what's weird is I can't pinpoint it, and I think it's internal. I can go to the back of the car, and the noise is projecting out of the tailpipes as well!! Sounds almost like some kind of bearing whine....hope not. Anyway, after about 30 seconds, I hear a noise that sounds like a turbo blow-off valve and the noise quits at that instant.....now, here lately when the car warms up, especially if the air conditioner is running, the oil pressure will drop between the 20 and 40 mark and bounce up and down a little. This car is my DD, so any help would be appreciated.
    That guy thearborbarber's Avatar
    SoDak
    White over Red
    1991 Suburban
    Sounds like the AIR pump kicking on and then turning off. Normal if that's it.
    Quote Originally Posted by thearborbarber View Post
    Well if it's that, then it's coming off anyway when I get my LT's. But why would I hear it only when I first start the car? Does the AIR pump only kick in when you first start the car, or does it come back on? And why would I hear it through the tailpipes?
    Member Orange99z28's Avatar
    joliet il
    orange
    99 z28
    yeah its only on the first few minutes after startin the car. the point is to get air to the cats faster. if anyone knows what else could cause this noise (pretty constant) please share, i'm worried about my engine at the moment
    Quote Originally Posted by Orange99z28 View Post
    I see. So it probably is my AIR pump. I bet the noise projects through the pump into the engine and out the tailpipes. Well, then this isn't much of an issue since it is being removed soon. And the oil pressure I have been monitoring, doesn't seem to be a problem, just a tick lower than normal with the AC, no bid deal. And it's just about time for an oil change anyway. So is your car making the same noise, or what?
    joliet il
    orange
    99 z28
    no, its a whistle, or whine i really can't tell. sounds like its coming from pass. side around the head. i took both pullies off and ran it - noise still there. when i start it it's not there, but as soon as i touch the gas it starts and keeps goin until i shut her down. also when i shut it off its like air pressure was built up and after the engine stops it kind of does a psss noise like i have a leak in some vaccum hose or something?? anyone got any info?
  1. Help: 2000 z28 clutch issues... need help!
    By mammoth713 in forum Camaro / SS
    Last Post: 09-30-2014, 07:13 AM
  2. Replaced Oil Pump. Low pressure, no noise.
    By Black LS1 T/A in forum Internal Engine
    Last Post: 12-14-2011, 06:36 AM
  3. Oil pressure issues
    By jrbonds in forum General Help
    Last Post: 07-20-2011, 10:35 AM
  4. Whining noise from exhaust, low oil pressure
    By 02pewterws6 in forum Internal Engine
    Last Post: 05-20-2010, 03:31 AM
  5. Help: 2000 SS with ASR issues
    By StilesAutos in forum Camaro / SS
    Last Post: 06-04-2009, 09:23 AM
