Thread: Oil pressure issues
07-20-2011, 07:44 AM #1
Oil pressure issues
So here's the deal. I read thread after thread and after thread. I got answers, but not enough, so I thought I would a few more detailed questions.
Over 100,xxx miles on motor.
1. My low oil light comes on about every 3 weeks. Oil level is usually low. But I also have a leaky oil pan gasket and valve cover gaskets and sometimes I just space out about checking the oil till that light comes on unless its oil change time.. Could the PCV stuff be leaky also? Where do I check for those?
2. Last week after extreme temps outside, my oil gauge starting floating all over the place. Never going below 20 PSI. But enough for me to take notice that it wasn't acting like it usually does. Since I have a gauge pillar pod, I want to install an aftermarket oil pressure unit, are there instructions on how to do this on a LS1 somewhere on the internet?
3. or should I just change the stock sending unit.
4. Last but not least, my worst fear.....what should I be looking for with a bad oil pump? I have no engine noise whatsoever. But I still would like some signs and symptoms of the oil pump going bad. Hell I don't even know where the oil pump is on this engine, I would assume in the oil pan, but I though I read that the oil pumps on LS1's were external. IDK.
Appreciate any information and advice you can give me.Last edited by jrbonds; 07-20-2011 at 07:47 AM.
07-20-2011, 08:55 AM #2Spaz is My Mentor
1. Yes The PCV can leak oil in several places. Not only that but also vacuum leaks. Ever since I change to the LS6 VCT and a catch can I haven't had to to top off my oil in 5 months. (yes I still check it)
2. I would be start looking for an oil pump. it jumping like that is a early sign that it's on it's way out. It also could be a bad OPSU. Replacing that would be a cheaper option to check first. THE OPSU does go bad and over time with many hot/cold cycles they become brittle.http://www.ls1.com/forums/f7/my-6-liter-build-174257/
6.0L Block - Forged 403ci
, Polluter Stg3 Cam, FAST 102mm Intake, NW102 TB, MSD wires, NGK TR6 plugs, Truck Coil Packs, LS3 Fuel Injectors, CC Pacesetter LT Headers, TS&P ORY, QTP e-Cutout, Magnaflow Muffler, 104mm Air Lid & Line Lock, Catch Can, Stage 2 T56 w/Viper shaft, PRO 5.0 Shifter, Tick MC, SPEC Stg3+ Clutch, QT SFI BH, MWC DSL, Full UMI Performance Suspension, Viking Coilovers, YR1 Snowflake Wheels wrapped in NT555 tires & Custom Fab Ford 8.8 rear w/Wavetrac Diff 3.93 Yukon Gears, WSQ Hood, 3"CM Strange Eng Drive Shaft.
07-20-2011, 09:25 AM #3Member
- Mar 2007
- NC
NBM- 1998Z28
This is a good spot to mount your oil sending unit for the pillar gauge. I hope you change your oil and just not keep topping it off or your motors gonna get sludged up.
07-20-2011, 10:35 AM #4Spaz is My Mentor
is that a kit or did you drill & tap yourself?
Noise and oil pressure issues. 2000 SS
By Y2KArcticSS in forum Internal EngineReplies: 5Last Post: 06-24-2008, 07:44 PM -
Having some serious issues.
By Banshee1967 in forum Suspension and HandlingReplies: 2Last Post: 03-31-2007, 07:45 AM -
What fuel pressure should I set my fuel pressure safety switch at?
By JAvery20 in forum NitrousReplies: 3Last Post: 04-01-2006, 03:59 PM -
Looking for gauges! nitrous pressure, fuel pressure!
By texasss in forum Parts Wanted / TradeReplies: 2Last Post: 10-29-2005, 09:05 AM
