    Lead Foot mammoth713's Avatar
    Jul 2009
    Upstate NY
    2000 Z28 M6
    2000 z28 clutch issues... need help!
    Having issues with clutch pedal in my 2000 camaro z28. Has 82k miles. I drew a diagram to help explain whats going on (I have searched the forums for someone with this same issue and have not found it). I think I wanna try replacing the master cylinder first before doing a whole clutch swap. What master cylinder should I get and where should I buy it? I saw there are adjustable master cylinders but I think it's overkill for my purposes. Do you think a master cylinder swap replacement would maybe cure my problem?
    In the event I do need a whole clutch swap, should I get an LS6 or LS7 kit? Both will work on my car right? Is the LS6 kit lighter? I have no intentions of increasing the car's horsepower so I'm fine if I used something like the ls6 clutch.
    Greensboro, NC
    2002 Trans Am WS6 M6
    Quote Originally Posted by mammoth713 View Post
    Probably need a new master cylinder. Don't use stock parts on this one. Get a tick performance master cylinder. Fixes the issues the stock master cylinder has. You will be much happier when you do. All of us have been.
    As for if you need a new clutch just get the LS7 clutch. It's pretty much a direct replacement. Typically everyone gets this one if they are not going with a monster or mcleod or something else. Still has the stock feel and holds up better.
    Jul 2009
    Upstate NY
    2000 Z28 M6
    the tick perf master cylinder is compatible with LS6/LS7 clutches? What slave cylinder works best with it?
    2000 Camaro Z28 M6: LM1, LID, KONI 4/3 SHOCKS, STRANO SPRINGS, UMI ADJ PHB, UMI STB, UMI 2PT SFC, UMI SWAY BARS.
    Tick MC works with all clutches while not all clutches work well with the Tick MC.
    Self adjustable clutches like the LS7 clutch only work when the clutch is new. If you install the LS7 clutch first than later on install the Tick MC you'll have some issues but if both installed new no issues.
    In regards to the slave get a stock gm slave cylinder. It seems to work best for all applications under 600ftlbs of tq. Thats more than the LS7 clutch is rated for and well over the stock clutch.
    Arizona
    That very tight disengage area in the diagram is the same issues we had with our 2000 SS. My wife wouldn't even drive it like that, and I admit it was a pain in the ass to drive.
    I prefer my engagement closer to the top just past half pedal travel. The adjustable master cylinder did that for us and was the best add on for a hydraulic system like this. Should have been adjustable from the factory in my opinion anyway.
    As far as clutches, everyone goes for the LS7. I however don't care for that "auto" adjustable pressure plate. So I avoid those clutches. Many years back I installed an LS6 clutch in my wifes car. With a small cam, LS6 intake and some other bolt ons. The car traps 110-112 mph in the heat and makes enough power to go low 12's. The clutch has held up just fine. My favorite clutch setup is Centerforce, and that's what will go in the car next time.
  1. Clutch issues
    By Tyjack17 in forum Manual Transmission
    Last Post: 12-08-2015, 07:19 AM
  2. Clutch Issues
    By V8MUSCLE in forum Drivetrain
    Last Post: 12-15-2014, 02:30 PM
  3. Clutch issues.
    By SilverBulletLS1 in forum General Help
    Last Post: 11-20-2013, 07:10 PM
  4. clutch hyd issues
    By werewolf in forum Manual Transmission
    Last Post: 12-28-2011, 04:18 PM
  5. LS7 clutch issues
    By rabiddog in forum Manual Transmission
    Last Post: 11-29-2009, 03:35 PM
