Results 1 to 10 of 10
Thread: Clutch Issues
12-15-2014, 07:51 AM #1Just a farmboy
- Jun 2007
- Montpelier, VA
Pewter- 2000 Pontiac Trans Am
Clutch Issues
Alrighty folks my 2000 Trans Am has been having some issues. When i push the clutch down i only have a clutch for about 6 or 7 seconds, after that Ive lost it. If i put it in first gear and hold the clutch pedal to the floor the car will start moving after a couple seconds, i have to put my foot under the pedal lift it up and pump it a couple times to get any sort of clutch back.
Ive bleed the clutch with a mity vac a couple times, put new fluid in it and nothing works. I do not loose fluid, no external leaks or loss of fluid in the reservoir.
Ive read on here that it is probably a master or slave cylinder issue so i guess my question is who makes a good one, ive heard good things about Tick and Mcleod just wondering if there was anything else i should look it.
Edit: Its been like this for about 3 years now, finaly starting to get some money and time to fix it.
Its also getting a little worse, I lost it for the first time driving down the road, went to hit the clutch to stop and there was no clutch, luckily i drive accordingly and had more than enough room to get it fixed and stop.
ThanksLast edited by V8MUSCLE; 12-15-2014 at 07:54 AM.
12-15-2014, 07:57 AM #2Spaz is My Mentor
Sounds like your MC is gone.
Stick with the gm slave. Most here use and recommend Tick MC's.
12-15-2014, 08:05 AM #3Just a farmboy
- Jun 2007
- Montpelier, VA
Is there a way to test and see for sure which is bad. replacing just the mc would be a lot easier.
12-15-2014, 08:05 AM #4Senior Member
- May 2013
- Nashville, TN
Black / White- '00 T/A M6/'19 Hemi Truck
x2 for the Tick MC
12-15-2014, 09:02 AM #5Spaz is My Mentor
Pretty much what you just did. Replace the fluid and bleed air out. If pedal continues to stick to the floor.
Slave has other symptoms.
12-15-2014, 10:01 AM #6
When my master went out I went with the new GM one. Don't remember the price difference but it was cheaper, and I didn't have any issues. No matter which one you go with change your fluid regularly and it will last longer.
http://www.rangeracceleration.com/Clutch_Care.html
12-15-2014, 11:24 AM #7Spaz is My Mentor
Well let me clarify. If you are sticking with a stock clutch then stay with GM. If you are upgrading or plan on upgrading with power mods then go with Tick.
12-15-2014, 11:39 AM #8
It has been years since I did mine. But at the time it seems that I read the factory master had been upgraded a bit from the original. What kind of hp do you think the newer factory master will handle?
12-15-2014, 12:00 PM #9Spaz is My Mentor
I really couldn't say, I just know my MC from my 98 was able to handle the LS7 clutch I had. Last summer because of doing a complete drive train upgrade I went with Tick to handle current & future power levels and also because I have a Monster Stg 4 clutch now.
Only major negative design flaw was the orifice was too small on GM MC's that while under rapid shifting (like at a track) the MC couldn't move fluid fast enough and grinding of the gears happen. That is why some do the drill mod to help that.
12-15-2014, 01:30 PM #10
Clutch issues
By Tyjack17 in forum Manual TransmissionReplies: 1Last Post: 12-08-2015, 06:19 AM -
clutch hyd issues
By werewolf in forum Manual TransmissionReplies: 19Last Post: 12-28-2011, 03:18 PM -
Clutch Issues
By BirdCountry02 in forum Manual TransmissionReplies: 5Last Post: 07-30-2009, 05:32 PM -
CLUTCH issues..
By foxman92 in forum Manual TransmissionReplies: 33Last Post: 07-19-2009, 10:40 AM -
Clutch issues
By JattGunMan in forum DrivetrainReplies: 6Last Post: 01-19-2009, 10:08 AM
