Thread: Clutch issues.
11-18-2013, 10:18 AM #1Junior Member
- Nov 2013
- Miami, FL
Pewter- 2000 Trans AM
Clutch issues.
to make this short and easy.. about a week or two ago, my clutch was getting soft and to the point that it would not even go into 1st or reverse.. and when it did if i lifted my foot 1 centimeter it would engage and car would start moving. come to find out my clutch reservoir was empty!! I filled it up with dot 3 fluid as specified. a day or two later it was empty again so I filled it up. it is slowly losing oil somewhere. I checked all the spots I have read online behind the pedal, under the brake booster even put cardboard under the car between engine and tranny to see if it was leaking and nothing no leaks whatsoever!! Where the hell is this fluid going?
11-18-2013, 11:46 AM #2Spaz is My Mentor
check the connector where the hydraulic hose connects to the slave. Sometimes they are not installed properly and can leak is damage.
Try filling the reservoir back up and have some one press the clutch pedal while you are under the car. A leak that bad has to show some where.
11-18-2013, 05:48 PM #3Junior Member
- Nov 2013
- Miami, FL
found the leak is this the slave?
11-18-2013, 06:13 PM #411 years of bangin gears
- Jan 2009
- North Jersey
Yep. Slave is bad. Speaking from experience.
11-18-2013, 06:14 PM #511 years of bangin gears
- Jan 2009
- North Jersey
You'll need a new clutch as well as some of the fluid has contaminated the clutch friction material.
11-19-2013, 07:57 AM #6
11-20-2013, 06:10 PM #7
No other way around that one. Pull the tranny and clutch.
Clutch issues
By Tyjack17 in forum Manual TransmissionReplies: 1Last Post: 12-08-2015, 06:19 AM -
Clutch Issues
By V8MUSCLE in forum DrivetrainReplies: 9Last Post: 12-15-2014, 01:30 PM -
clutch hyd issues
By werewolf in forum Manual TransmissionReplies: 19Last Post: 12-28-2011, 03:18 PM -
Clutch Issues
By BirdCountry02 in forum Manual TransmissionReplies: 5Last Post: 07-30-2009, 05:32 PM -
CLUTCH issues..
By foxman92 in forum Manual TransmissionReplies: 33Last Post: 07-19-2009, 10:40 AM
