    SC
    2000 SS Camaro
    2000 SS with ASR issues
    hey i have a 2000 SS with the ASR option.. The ASR, ABS, and Brake lights are all on.. Now they will all go off every now and then and stay off for 10 to 15 minutes.. The ASR switch does not function when they are lit. Any ideas as to why all three would be randomly coming on like this.. All of the fuses on the dash and under hood check good. Any help of where to start would be greatly appreciated.
    SS Driver aerojt's Avatar
    Ohio
    1998 Camaro SS M6 #1871
    I have the "ASR OFF" light permanently on right now. Not sure of the reason, but I am going to take it to a service person soon. My switch does nothing, I have no traction control, but I do have ABS....
    Member FullBlack4thGen's Avatar
    Mar 2009
    Longisland
    98 Z28
    I believe there's an ASR bypass box that can be installed. Maby you have one of those installed?
    Member Sayed_000's Avatar
    Middle East - Bahrain
    Camaro 2000 SS M6
    i'm not that pro but i believe its an elec. problem there ..
    i had the same problem with my ASR .. the ASR is related to the lower air sensor and there was an wire which was unplugged and i plugged it back ..
    Indianapolis
    2000 WS6 6spd Hooker LT
    Sounds like an ABS wheel speed sensor is flaking out on you. The ASR gets info from the ABS wheel speed sensors, if one of those sensors is failing it will do just as you describe. You need to get the system scanned.
    Ohio
    Quote Originally Posted by Sayed_000 View Post
    Where is this lower air sensor and wires? Thanks.
    Camaro 2000 SS M6
    behind the Air Mas Flow ..
    Royal pain in the.... Phantom2kz's Avatar
    savannah, ga
    2001 Z-28 A4 NBM
    2002 35th anni SS M6#1696
    that is intake air temp will not turn on asr or brake lamp, just check engine
    if ASR and red brake lamp are on you have a severe ABS/asr issue.
    a wheel speed sensor will only put on ABS lamp, not red brake lamp
    sounds like a EBCM electronic brake control module, the electric half of the ABS unit. try and have the codes scanned..if it needs one i would try one from a bone yard or E-bay before paying for a new one.
    i needed one for mt 2000 z, got it for less then 100 on flea bay,worked like a charm
  1. Help: 2000 z28 clutch issues... need help!
    By mammoth713 in forum Camaro / SS
    Last Post: 09-30-2014, 07:13 AM
  2. 2000 Pontiac Pirahna - Department X: The 2000 Piranha Concep
    Last Post: 10-05-2012, 04:20 PM
  3. Poss buying 2000 TA (issues I should look for?
    By knightryda01 in forum Firebird / WS6
    Last Post: 08-01-2008, 03:30 PM
  4. Noise and oil pressure issues. 2000 SS
    By Y2KArcticSS in forum Internal Engine
    Last Post: 06-24-2008, 07:44 PM
  5. 2000 auto z28 VS 2000 m6 formula
    By silverz28camaro in forum Kill Stories
    Last Post: 06-24-2007, 07:59 PM
