Thread: Is Fast the only intake answer?
06-17-2008, 02:50 PM #1Junior Member
- Dec 2005
- Sanford, FL
Black- 98 SS
I have another thread about the engine but I'm also wondering about the bang for the buck in an Intake. If this has been covered a thousand times then please just point me to that archive
So my question is; on a larger then stock LS engine it seem that Fast makes the best intakes, but are there some decent alternatives for around $500.
Fast 92mm, 90mm, 78mm
Weiand intakes,
BBK intakes,
Typhoon intake 96mm & 85mm
LS6 obviously.
I'm coming from an LS1 so anything is better then my LS1 intake but what about these others? I've been told that really only Fast is better then the LS6 because of heat-soak in the others (anything non nylon) reducing their efficiency/hp gains. If you didnt have the money for the Fast, what would ya buy? Thanks again you guys are great.
Jeff
06-17-2008, 06:44 PM #2member since may 2000
- Dec 2002
- n/w chicago
Weiand and hog it out.
heat soak isnt that big of an issue.
the air isnt even in the intake for a second2000 nhra edition formula
a few bolt ons, 379 rwhp
11.96 @113.25
06-19-2008, 03:40 PM #3
06-21-2008, 07:42 AM #4Junior Member
- Dec 2005
- Sanford, FL
Black- 98 SS
I'm bolting a 408 onto the Camaro but I can't afford a Fast (go figure). There has got to be someone out there that has tried other intakes.
jeff
06-21-2008, 10:32 AM #5M3+LS1=Badass
- Jan 2008
- lex-town, ky
Cosmos black- 1995 BMW M3
What kind of heads and cam?
I would take a guess that the FAST flows a tiny bit better than the stock LS6, so if you have really highflow heads with a big cam, then get the FAST.
Otherwise I'd bet that the LS6 intake will flow enough for your needs
06-25-2008, 10:26 AM #615 sec. Oh yeah, its fast
- Apr 2007
- Forest Lake, MN
maroon- 2000 Z28
I see a lot of people with larger cubed motors using the Victor Jr. intakes.
06-25-2008, 03:59 PM #7
I hear that most people are happy with the gains from an LS6 intake. And it helps more with other bolt-ons.
Ls6 or fast intake?
By 99yellowz28 in forum External EngineReplies: 41Last Post: 03-24-2014, 07:42 AM -
Help: LS6 Intake? Need a Quick answer ASAP!
By SMWS6TA in forum General HelpReplies: 4Last Post: 09-08-2010, 08:53 PM -
Hurry I need an answer fast
By screaminbird in forum Manual TransmissionReplies: 5Last Post: 08-03-2009, 01:51 PM -
FAST LSX intake
By Naf in forum GTOReplies: 13Last Post: 12-17-2006, 02:16 AM -
LS6 intake or FAST 78mm intake
By SSwt00SS in forum External EngineReplies: 10Last Post: 07-26-2006, 12:50 PM
