    LS6 Intake? Need a Quick answer ASAP!
    Need a quick answer on this one from those of you that have installed a LS6 Intake!!
    I ordered the LS6 Coolant bypass line, but I only ordered one. I'm looking at the pics on ls1howto.com and I see what looks like I need 2 of them.
    http://www.ls1howto.com/index.php?article=5
    Is this true, do I need a second one?
    Please hurry I need to order asap in order to install this weekend.
    I think I just got my answer. The kit I order has plugs for the rear. It also doesn't have instructions, that would be a nice thing to have.
    But still want to know any tips that will help
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    I did the one pipe in front and 2 plugs in the rear...just like the factory did it.
    Thx Cutlass. The kit just look weird compare to the instructions on ls1howto. I had to reread them a couple of times to understand what he meant. After looking at the kit I can see how it goes in now. Still it would have help if it (the kit) came with some instructions.
    How long should it take to do this swap out? I'm thinking about 3 taking my time and not rushing it.
    swapping the intake? First time ever?? Hour or so. I can do it probably in 15-20 minutes after having done it a few times. Watch the oil pressure sender on the drivers side rear of the block. That big vacuum line going to the booster will break it and it's very easy to break. Watch the torque on the intake bolts too. Don't take much and they're in IN/lb's and not foot lbs.
  1. Question: Need answer ASAP!!!!! Verify the Reluctor Wheel on a 04LQ4
    By SMWS6TA in forum General Help
    Last Post: 05-16-2012, 01:11 PM
  2. Need answer to this..ASAP
    Last Post: 05-18-2009, 06:34 AM
  3. Looking for a quick answer
    By matt123 in forum Manual Transmission
    Last Post: 07-25-2007, 03:59 PM
  4. back spacing ? need answer asap.
    By 1fastcamarosss11 in forum Wheels and Tires
    Last Post: 08-29-2006, 06:23 PM
  5. Need ANSWER quick
    By SexyAssFormula in forum Wheels and Tires
    Last Post: 06-14-2006, 08:25 AM
