Results 1 to 20 of 42
Thread: Ls6 or fast intake?
03-08-2014, 07:43 AM #1
Ls6 or fast intake?
I'm about to order a tsp torquer v2 cam and I want to do a intake at the same time the only thing done to the motor is headers and tb bypass but down the road I will be doing heads so I want to do it right the first time. I'm not going to go crazy with the car I'll probably stop at some mild heads. Also is a new throttle body necessary on either intake? And if fast is recommended which size? I figure 92 is big enough
03-08-2014, 08:04 AM #2Spaz is My Mentor
Ls6 or fast intake?
What are your plans? Meaning slight track/street use or heavy?
Light I recommend the LS6 intake. Really good and for the price best bang for the buck.
Heavy track - You'll want a FAST 102. The 90's are no longer made so it will be used. 102's require more than a simple intake swap. Your looking at injectors, upgrade fuel pump, throttle body & tune to get full benifit.
IMHO FAST are for guys that are serious into racing. Total overkill for DD/ mild street track use.http://www.ls1.com/forums/f7/my-6-liter-build-174257/
6.0L Block - Forged 403ci
, Polluter Stg3 Cam, FAST 102mm Intake, NW102 TB, MSD wires, NGK TR6 plugs, Truck Coil Packs, LS3 Fuel Injectors, CC Pacesetter LT Headers, TS&P ORY, QTP e-Cutout, Magnaflow Muffler, 104mm Air Lid & Line Lock, Catch Can, Stage 2 T56 w/Viper shaft, PRO 5.0 Shifter, Tick MC, SPEC Stg3+ Clutch, QT SFI BH, MWC DSL, Full UMI Performance Suspension, Viking Coilovers, YR1 Snowflake Wheels wrapped in NT555 tires & Custom Fab Ford 8.8 rear w/Wavetrac Diff 3.93 Yukon Gears, WSQ Hood, 3"CM Strange Eng Drive Shaft.
03-08-2014, 08:20 AM #3
the car is mostly driven on the street every once in a while I go to the track but not often. The car is also not a dd I only take it out of the garage if its going to be a nice day
03-08-2014, 02:38 PM #4Senior Member
- Mar 2009
- pompano beach florida
- 2002 Camaro Z/28 Pewter
The 90's are not made anymore but the 92 certainly is. However instead of gray they are black fast reintroduced them a couple years ago. I would go with that as mentioned the 102 requires a maf relocation and different fuel rails along with injector extensions. The 102's hp difference over the 92 is only a few hp better than a 90 or 92 due to its different runner design
03-08-2014, 03:01 PM #5Senior Member
- Aug 2007
- Greensboro, NC
Pewter- 2002 Trans Am WS6 M6
Ls6 will be your best bang for the buck. You can get them ported and they will perform up there with the fast 90/2. If you want to make the most of the heads and cam then the 102 is the way to go.
03-08-2014, 07:58 PM #6Senior Member
- Apr 2010
- Alabama
Um there is so much wrong here. I have a 102 and injector extensions are not needed I used a spacer in between the fuel rail to raise it up. Also I am thinking you meant MAP and not MAF relocation but that is not required either I can show a picture if you don't believe me but mine is in the same spot as stock with no problem. Btw the 102 is a reasonable amount better than the 92 unported vs unported that is and costs about the same so it just comes down to whether you want to swap fuel rails. Also mine uses a "stock" fuel rail, the ls2 fuel rail works perfectly. If you are going to buy a FAST the 92 shouldn't even be a consideration and you should go all out if you have decided to spend the money on one.
1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
03-09-2014, 01:24 AM #7
Last I saw, the FAST intakes were just under $1,000... I do like the look of the black 92's a lot more than the gray on the old 90's. FWIW the Trick Flow head and cam kit that makes 515 hp is measured utilizing the stock LS6 intake, so it does work well.
03-09-2014, 07:11 AM #8
What kind of spacers are required to make the 102 work? I been looking at these and had thought about getting a 92 because I don't think I will out flow it and need a 102 but I may be wrong. Also when using a 92 or 102 will my slp bellows boot fit over the throttle body if I get the matching throttle body and with just a cam, intake and headers is the stock tb to small?
03-09-2014, 07:36 AM #9Senior Member
- Apr 2010
- Alabama
The spacers come in a ls2 oem fuel rail kit made by FAST but here is what they look like.
MAP in oem location
You can't use the stock TB with the FAST 102, you need at least a 90mm but I would get a 102mm if you are buying one. It would be pretty pointless to upgrade to the FAST and use a stock TB. The only way perhaps possible to use the stock TB with the FAST is maybe with a reducer. If you have any more questions feel free to ask. The smooth bellows will definitely not fit over a 102 TB unless maybe you heat it up but I am unsure on that. It may not even fit the 92 it depends how wide it is and how much give it has to it. Regardless it is easy to find a silicon coupler that will work just measure the length of yours and get a 4" one that is as long as yours. I found one on ebay that was 4 " X 6" and it works great. I needed 6" for length because I don't use a MAF as I am speed density tuned.Last edited by 98TransAmWs-6; 03-09-2014 at 08:28 AM.
03-09-2014, 08:46 AM #10Senior Member
- Apr 2011
- Johnstown,PA
Silver- 1999 Trans-Am, 2012 Sonic
I just picked up my LS6 intake for $350 shipped to my house and have another $300+ in odds & ends. You could go with 28lb injectors as your 99 has 26's but after talking with my tuner(Frost) he said not nessery until I do heads & Cam. Also I will be sending my PCM to him for a retune($50) and egr delete. LS6 intake is worth 25rwhp on a bolt on car LS1Howto.com
Your TB would be fine as well 75mm or pick up a ported one or do it your self and it would be close to 78mm. The stock LS6 is a 80mm
Your direction of build sounds just like the direction I'm headed with a Mild Cam & Head package so I would think the LS6 would perform perfectly at a fraction of cost that you would get into for a Fast. Jmo. Just a guess I would think you would be $2,000+ to do Cam & Fast, and a 102 would be overkill for what you described as the direction you wanted to go in post #199 Trans Am, SLP Lid, Blackwing filter, smooth bellow, Ported TB, LS6 intake, Ws6 lower ram air box, OBX LT's, Magna Flow cat back, LS7 clutch, Tick MC, Hurst Shifter, Frost Tune, UMI SFC,LAC, STB, PB, Torq Arm, Super Hawk hood, Torq Thrust II, Kee Audio.
Strange S60 4:10's, D&S Rotors, S/S Brake Lines.
Nitto NT05R Track Tire's, 12.7 @ 108 / 1.82 60'
Wish list.
Coil overs, Heads & Cam
03-09-2014, 09:10 AM #11
so do you not have ls1 fuel rail? the 102 seems like it will cost another 300-400 more by the time you do the fuel rails and the throttle body is about $100 more (fast brand). Is there really that big of A diffrence between the 92 and 102 when building a h/c car because im ot planing on any n2o or power adders
03-09-2014, 09:24 AM #12Senior Member
- Apr 2010
- Alabama
If you are bent on using the stock fuel rail or mind spending the extra money for the other stuff needed to run the FAST 102 , then it is not for you. I was talking about the price for just the intake but yes there are items you need in order to be able to run the FAST and I use the ls2 fuel rail kit. If you are trying to squeeze the most you can out of the motor then the FAST 102 is the choice. To me it is only a couple hundred extra for the fuel rail kit vs the 92 and if you are going to spend the money on a FAST to begin with you should go with the 102 otherwise I would stick with the ls6. I can't really say how big the difference is but the 102 will make more power. With a stock cubed motor it may not make that much of a difference but I am building a stroker and always planned on so which is why I got the 102. I wouldn't buy a FAST brand TB I bought a Nick Williams 102 TB and they are about the same price regardless of size and much cheaper than the FAST brand.
03-09-2014, 10:07 AM #13Senior Member
- Apr 2011
- Johnstown,PA
Found this on line swapping to a 102
Fast LSX Intake Parts
146302 $979 Fast 102mm intake for LS1, LS2, and LS6 cars
54102 $510 Big Mouth 102mm Throttle Body
54028-KIT $125 Fuel Line Conversions Kit for ’98-’02 LS1
146032-KIT $193 Billet Fuel Rail Kit for LSXR LS1
Everything I read the 92 & 102 are better Than the LS6 by 10- 15 H.P. with a mild cam and head package and even better with bigger and badder stuff how ever the price commitment on a lightly modded motor was always brought into question. Hey worst case you choose to go with a more aggressive package down the road put your LS6 up for sale. They don't last the day over on Tech when listed. The best thing you could do is keep reading reviews and check your wallet and go from there...lol
03-09-2014, 10:11 AM #14Senior Member
- Apr 2010
- Alabama
Damn I only paid $823 for the intake, $400 for the TB and $200 or so for the fuel rail and spacer kit. I bought this all from the WS6TORE and I believe the prices are still the same.
03-09-2014, 11:08 AM #15
I have been going off the texas-speed.com website because that's where I'm ordering the cam. I'm more leaning towards the 92 because of additional cost compared to the 102 and I'm not going to build a big motor just cam now and mild heads later so 102 just seems to be over the top plus where the red fast logo is I want to sand and paint yellow to match the car.
03-09-2014, 12:53 PM #16
03-10-2014, 05:11 AM #17
This has all been talked about before. Alot of it is a matter of what you want out of your car and how much you are willing to spend to get it there.
From what you mentioned in your post about primarily being a street car with very seldom or occasional trips to the track for fun, personally I wouldn't spend the coin on a Fast intake setup. Before it's done you'll have $1500 and likely much more in that intake setup. On a mild build like yours where the intake might be worth 10-15 HP that's a pretty big chunk of change for very little gain.
The LS6 intake is cheap and it works. Plenty of 10 second (motor only) cars out there using it. You won't be going that quick with mild mods you have planned, so why spend a ton of money on a Fast when the LS6 will do what you want?
03-10-2014, 02:32 PM #18
03-10-2014, 05:32 PM #19Spaz is My Mentor
Ls6 or fast intake?
I think I said it well in post 2....
03-10-2014, 07:22 PM #20
I agree with you guys the more I look into it the more the ls6 seems the way to go. Now to get one
Fast Intake & N20 Kit..
By Click-6 in forum Western MembersReplies: 11Last Post: 05-31-2009, 07:56 AM -
FAST 90 Intake
By Whiteboycntdnce in forum Parts For Sale / TradeReplies: 5Last Post: 12-12-2008, 09:13 AM -
Wanted: LS6 Intake or Fast 90/90
By chieftransam in forum Parts Wanted / TradeReplies: 1Last Post: 05-14-2008, 08:06 PM -
FAST 90 mm Intake !
By chiws6 in forum Parts For Sale / TradeReplies: 10Last Post: 04-02-2007, 05:22 PM -
LS6 intake or FAST 78mm intake
By SSwt00SS in forum External EngineReplies: 10Last Post: 07-26-2006, 12:50 PM
