Results 1 to 11 of 11
    DFW
    '18 CTS-V
    '13 ZL1
    LS6 intake or FAST 78mm intake
    Ok, I'm stuck. Current mods are in my sig. I just took delivery of my MAC mid-tubes and ORY tuesday to get installed and I'm wondering if I should go with the the LS6 or the Fast 78mm for an intake. Obviously I can use my stock TB with both, but the Fast flows approx. 15% better than the LS6 (hence little more power and TQ?). Im not concerned w/cost as most LS6 intakes I see are going for about $400 and the Fast is around $650. My goal after install and tune of these parts and with the cam being able to breathe better on both ends is about 390-400rwhp.
    What are some thoughts out there about each intake respectively? Thanks.
    2013 ZL1: °°590rwhp/576rwtq°°
    Dec 2002
    n/w chicago
    2000 nhra edition formula
    you have no need for the fast intake. if you had bigger cubes or a big cam, then i would suggest it.
    the ls6 will work fine.
    look for used ls6 manifolds, they can be had for 300
    a few bolt ons, 379 rwhp
    11.96 @113.25
    Gulfport
    2000 trans am ws6
    yeah I agree, I would not spend that much on the 78 Fast, If I was gonna spend that much Id just go ahead and go with the 90/90set-up. There is always a used LS6 intake for sale, I got mine for $50, so Id check around before Id buy a new LS6
    Wahiawa hi.
    big cubes calls for the 90mm, the 78 will work better than an LS6 on small/stock cubes.
    Lost in Texas
    Custom Slate Blue
    99 B4C
    on your motor you won't make use of the 78mm, you won't benefit much from it. Just go LS6
    SFL Drifters
    Florida
    2002 TransAm WS6
    u can get away with the LS6 intake if u want low end but if u want top end get the fast 90mm,
    Knoxville, TN
    Torch Red
    2000 Corvette
    The LS6 intake is worth the price of admission. For the money, it will improve performance and you can still use your stock TB. If you want to make gains above the LS6 intake, then go with the 90mm intake and TB. The 78mm is little or no improvement over the LS6 stuff. With your current set-up I recommend staying with the LS6. If you do more modifications, then think about the 90.
    Senior Member ninobrn99's Avatar
    Aug 2003
    Honolulu HI
    all bore 370 Trans Am
    if you plan on getting a bigger cam later or better heads, then you should go with the fast 90/90. Again, you will gain top end, but sacrifice some lowend grunt for the fast setup. The LS6 intake isnt a bad intake and isnt that restrictive until you start getting heavily modded, but for a very mild cam only setup as yours, it should be plenty. The best advice I can give you is this: If this car is mainly a street car and sees the track every so often, then build it for the street and enjoy it those few times you take it to the track. Focus for power throughout the powerband. If its gonna be at the track more than anything, then focus on topend power. Bigger cam, intake, heads, rearend..and all that stuff that goes along with it.
    Nino
    DFW
    '18 CTS-V
    '13 ZL1
    thanks guys. the more i think about it, i really want more of a street car than strip. a good cruising car, that will take out most anything that comes my way. with all thats done and soon to be done to my car i'll be happy with 375rwhp for the time being.
    I picked up a new LS6 intake over the weekend off Ebay, so I hope that it comes in about a week. then I will have the intake and the headers to get installed at once and then re-tuned. i will keep you all informed, and post numbers too!
    Aug 2003
    Honolulu HI
    sweet! The key is being honest with yourself on what the car is going to do. Then you mod Dont be dissapointed by your peak numbers. Look at area under the curve. thats what counts.
    Gulfport
    2000 trans am ws6
    You can always sell the LS6 down the road for about $300 and that would make the 90/90 setup that much cheaper
  1. LS6 intake or Fast Intake??
    By 99TransAmSLP in forum Firebird / WS6
    Last Post: 02-28-2009, 09:22 AM
  2. Fast Intake 92mm v 78mm
    By Ghawk996 in forum External Engine
    Last Post: 10-09-2008, 09:38 PM
  3. WTB 78mm fast intake
    By kyemt in forum Parts Wanted / Trade
    Last Post: 07-23-2007, 11:24 AM
  4. WTS:NIB FAST Intake 78mm & 90mm
    By BMG50 in forum Parts For Sale / Trade
    Last Post: 06-15-2007, 12:06 AM
  5. FAST LSx intake and throttle bodies... 78mm vs 90??
    By 99_LS1 in forum External Engine
    Last Post: 03-28-2007, 07:24 AM
