Results 1 to 19 of 19
Thread: Rear End Howl
12-20-2005, 12:41 PM #1Junior Member
- western mass
black- 2005 gto
Rear End Howl
Anybody have this problem: after about driving 10 miles i get a low level howl from the rear end, checked the level it" at the top , if i slowly excellerate the noise goes away or if i let off gas , holding steady speed it"s noisey. 05 a4
12-20-2005, 12:57 PM #2SUPREME member-oderator
- Nov 2005
- Lost in Texas
Custom Slate Blue- 99 B4C
If I had a 2005 gto that answer to all of my problems would be warranty. Every problem has the same solution then -drop it off and pick it up
12-20-2005, 04:42 PM #3Grand Imperial Wizard
- Retired Outlaw Sum Bitch
Lots and lots of folks have had this issue....most dealers are replacing the pinion under warranty......the majority of folks have replaced the fluid with Royal Purple 85-140 with the friction modifier in it already and killed the diff whine issue......
12-21-2005, 01:16 PM #4Junior Member
- western mass
black- 2005 gto
Sarge thanks for that info I really didn"t want to bring it in to dealer because of recall on waring buzzers not working i guess they have to do a reflash to turn on this feature / I like it with no warning buzzers going off / seat belts /key in ignition ect. / i will try the fluid change as you said.
12-21-2005, 06:54 PM #5
you should definatly bring it back to the dealer and have it fixed or replaced worst thing that could happen is new parts. The royal purple might just hide the problem
12-22-2005, 04:30 AM #6Grand Imperial Wizard
Well much of the issue has been found in crap diff fluid in the cars when delivered......thus causing the pinion to go south due lack of proper lubrication...also many have had the dreaded single tire burnout as the OEM fluid doesnt allow the posi to lock up correctly.....Amsoil and RP have eliminated this in almost all who have replaced the fluid....
12-22-2005, 09:36 AM #7x-GTO Owner still love em
- Dec 2005
- Michigan
Graystone- 2006 Silverado Z-71
Has this been a problem with the 2004s as well? My car was a factory buyback. The guy who owned before complained enough about this problem and GM actually bought the car back. It then went to the GM Technical Assistance Center for evalutation. It came back with nothing wrong with the car. I bought and they gave me an extra 12 months/12000 mile warranty that covers all, even brakes (so they say).
12-22-2005, 09:38 AM #8Grand Imperial Wizard
Yup...same rear end in 04's......GM has a Technical Bulletin out on it...but no recall......
Originally Posted by ctbeiser
12-22-2005, 09:45 AM #9x-GTO Owner still love em
- Dec 2005
- Michigan
I have noticed before the single tire burnout. That explains it. I think I will make the switch. Any Recommendations.....Amsoil or RP and weight? It is probably a preference.
I did not realize the RP weight was already given above.Last edited by ctbeiser; 12-22-2005 at 09:49 AM.
12-22-2005, 09:50 AM #10Grand Imperial Wizard
I ran Amsoil 75-140 with Amsoil friction modifier and it was "better"...Royal Purple 85-140 with the friction modifier already in it and it was totally gone and I have had zero issue since.....NAPA sells the RP for like $7-8 bucks a quart... http://www.royalpurple.com/prodsa/mgeara.html
12-30-2005, 12:07 PM #11Junior Member
- western mass
black- 2005 gto
I changed the rear end oil to the r.p. the noise is all but gone only a slight noise at 45 mph at lite throttle thats it / THIS REALLY WORKS./
12-30-2005, 12:33 PM #12Story of My Life!!
- Commerce Ga
Black, Blue- 07 TBSS, 07 GSXR1000
I think that I'm going to try that.
01-12-2006, 09:34 PM #13Junior Member
- Jan 2006
- Florida
Blue- 2004 GTO
beano helps
01-13-2006, 03:06 PM #14Junior Member
- western mass
black- 2005 gto
When you said beano are you refering to castor bean oil?
01-13-2006, 03:15 PM #15Grand Imperial Wizard
He's jerking your tallywhacker....I'll biatch slap him for you....
01-14-2006, 07:34 AM #16Junior Member
- western mass
black- 2005 gto
Thanks!
01-17-2006, 06:21 PM #17Junior Member
- Jan 2006
- Houston, TX
Impulse Blue- 2004 Pontiac GTO
This is what I would recommend, worked well for me and many others.
Originally Posted by Sarge
01-17-2006, 06:36 PM #18txcosmosGuest
mee toooooooo
01-21-2006, 04:56 PM #19
a lot of that noise comes from improper pinion backlash also...but changing fluids def help..
Question: gear howl?
By JDCAMARO99 in forum DrivetrainReplies: 8Last Post: 04-22-2015, 04:34 AM -
Rear alignment issues after removing rear spring isolaters, adj trac bar fix it?
By anestech* in forum Suspension and HandlingReplies: 1Last Post: 06-19-2007, 07:06 PM -
Randy's Rear End Shop Get's Punked (Prank) - Woman looking for a bigger rear!
By powermelissa in forum Multimedia SectionReplies: 0Last Post: 05-25-2007, 10:37 AM -
howl sound?
By therobman in forum Firebird / WS6Replies: 16Last Post: 05-04-2007, 09:44 AM -
Rear end howl
By 1986camarojoe in forum DrivetrainReplies: 3Last Post: 10-11-2006, 03:28 AM
