Results 1 to 17 of 17
Thread: howl sound?
03-05-2007, 05:49 AM #1Junior Member
- Aug 2006
- no where
howl sound?
i didint know where to post this so im posting it here i have a 2000 trans am a4 with 35000 miles and when im in like 4th gear at like 2,000 rpms and i tap the gas i hear a howl sound like comming from the back of the car it also happens when i slow down anyone have a clue why?
03-05-2007, 07:42 AM #2Detailing + Design
- Pittsburgh, PA
tap the gas and continue accelerating?
Does the sound dissapear as you accelerate?
Does it only occur in fourth @ 2000 or any gear at 2000?
03-05-2007, 09:14 AM #3Bone it like you own it
- Sep 2005
- TEXAS... U mad?
Black / Stryker Blue- 2K WS.6/ 2K9 G8GT
mine makes a howling between 2100- 2400 rpms when im on the gas at all, just the way your exhuast is probably.
03-05-2007, 12:46 PM #4Junior Member
- Aug 2006
- no where
no its just when i tap the gas in 4th or when i slow down and its not the exhuast cause this started like 3 days ago
03-05-2007, 02:08 PM #5
03-05-2007, 03:19 PM #6
i ran over retread from a truck and it bent my y pipe up a little and made an awful racket at a certain RPM.
03-05-2007, 04:32 PM #7Detailing + Design
- Pittsburgh, PA
therobman: please explain "tap"
03-05-2007, 06:22 PM #8Junior Member
- Aug 2006
- no where
like havin the car in od aka 4th gears and like tapping the pedal like maybe a quarter way down and letting off and i hear it slowing down otherwise i dont hear it its not a wine so i dont think the rears bad or is it?
03-06-2007, 02:59 PM #9Attending F-Body Expert
- Jan 2006
- Beverly Hills, Malibu, Laguna Beach, Hollywood....I WISH.
Triple White Convertible- 1997 WS6 'Vert Trans Am
my brothers 99 TA did a whining noise like that -but it was kinda steady noise and it was even when cruising and accelerating.... his rearend was going out..... Sure hope that isn't your problem. (although it's an excuse for new gears
HL
03-06-2007, 04:46 PM #10
its not really a winning noise...its more of a howling....mine does it too when im in like 4th gear at low rpms and i tap the gas, its really annoying
03-06-2007, 05:39 PM #11
i seriously think mine has something to do with the exhaust. i don't hear it all the time though. it'll be awhile before i get my car done to track down that problem but y'all let me know if you figure it out.
03-06-2007, 05:51 PM #12Mosler MT900 S
- Jan 2007
- Rhode Island
Arctic White Hardtop- '98 Formula M6
I have had the same problem ever since I got my car a few months back (I have a stock exhaust setup). I'm beginning to get used to it, but after carefull consideration, I think its the noise of the stock muffler squeezing down on the exhaust being shot out (restricting the flow). In another words, if you had no muffler at all, the noise would be non-existant (although much louder in a tottaly different way). Whenever I hear that noise, I just step back down on the throttle, make it dissapear, and pretend I have an aftermarket exhaust setup with better flow.
03-06-2007, 06:05 PM #13Junior Member
- Aug 2006
- no where
i braught my car to the shop to have new gears put in and he said it was either the bearing or the pinion and the posi was in pieces so 550 bucks later its fixed with a set of 3.73's
03-06-2007, 06:45 PM #14Mosler MT900 S
- Jan 2007
- Rhode Island
$550????????????
Um, Im no expert, but that seems like a lot of money for somthing like that. Considering whoever "fixed" it dident know what exactly was wrong with it. Maybe im just cheap, I dunno.
03-06-2007, 07:30 PM #15Junior Member
- Aug 2006
- no where
no it was for the part + the gear install so actally it was cheap cause the part was 225 and the gear instalation kit was 100 so it was a good price
03-06-2007, 07:36 PM #16Mosler MT900 S
- Jan 2007
- Rhode Island
Oh thats good, that seems just about right.
05-04-2007, 09:44 AM #17
i had a holing noise too similar to that and it turned out to be the axle bearings...from what i hear tho it might be the rear...3.73's????!!! yes sir
Screeching sound coming from rear of the car - sound clip.
By Tataocb in forum General HelpReplies: 45Last Post: 07-21-2016, 08:12 AM -
Question: gear howl?
By JDCAMARO99 in forum DrivetrainReplies: 8Last Post: 04-22-2015, 04:34 AM -
How's this sound?
By SMWS6TA in forum Almost Anything GoesReplies: 2Last Post: 09-20-2009, 04:21 PM -
Rear end howl
By 1986camarojoe in forum DrivetrainReplies: 3Last Post: 10-11-2006, 03:28 AM -
Rear End Howl
By wingnut in forum GTOReplies: 18Last Post: 01-21-2006, 04:56 PM
