Thread: Rear end howl
09-29-2006, 10:01 PM #1
Rear end howl
Yea so I got this annoying whine/howl coming from my rear end, it's all stock, gears too. I jacked it up and spun my tires around with my hands and it doesn't make any noise. I've been told it could be my gears or a bad wheel bearing, anybody know? If this thing is broken to where I need major repairs I'll probably just buy a 12 bolt or a 9 inch, who makes a direct bolt in, and where can I look at them?
10-04-2006, 12:50 PM #2
is it at certian rpms or all the time?
10-04-2006, 09:52 PM #3
I can only hear it at low speeds, but I already took it in to get checked, a bearing went out and now my gears are worn down sooo time for a new one.
10-11-2006, 03:28 AM #4Member
- Oct 2005
- Vicksburg. Ms.
pewter- 99 Trans Am
I have a vibration at 3000rpm and up and it gets worst the faster you go,can this be rear end related?I have exchanged u-joints,driveshaft and checked the axles.I have checked trans mounts and replaced the harmonic balancer.What can it be ? the trans is a automatic.Need some input.I have all but given up.Can the trans be at fault?I ask because it has been worked on lately, but I had some virbation before it was worked on.I didn't mean to take over this post but I just wanted to ask after this was related to my problem also.The car here is a 77 camaro,not my TA.
Question: gear howl?
By JDCAMARO99 in forum DrivetrainReplies: 8Last Post: 04-22-2015, 04:34 AM -
Rear alignment issues after removing rear spring isolaters, adj trac bar fix it?
By anestech* in forum Suspension and HandlingReplies: 1Last Post: 06-19-2007, 07:06 PM -
Randy's Rear End Shop Get's Punked (Prank) - Woman looking for a bigger rear!
By powermelissa in forum Multimedia SectionReplies: 0Last Post: 05-25-2007, 10:37 AM -
howl sound?
By therobman in forum Firebird / WS6Replies: 16Last Post: 05-04-2007, 09:44 AM -
Rear End Howl
By wingnut in forum GTOReplies: 18Last Post: 01-21-2006, 04:56 PM
