Results 1 to 2 of 2
    Las Vegas, eNVy
    2001 Trans Am
    Rear alignment issues after removing rear spring isolaters, adj trac bar fix it?
    So, I did the Koni SA 3/4 drop, and the heater hose in place of the rear isolater drop. Now, I'm having rear alignment issues. An adjustable rear trac bar should fix this, right? Basically, the rear thrust angle is off, so the car pulls to the right and "crabwalks" a little, even though the front aligment is perfect and all 4 tires are new.
    I didn't think this would be an issue with such as little drop, but I guess it is...
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    no. adjustable trailing arms will fix that. for it to be that far off, means something is drastically wrong.
    what are the perfect alignment specs? front and rear.
  1. Wanted: left rear ABS speed sensor for 01 WS6 A4 W/ trac
    By Willfully Armed in forum Parts Wanted / Trade
    Last Post: 05-05-2016, 03:06 AM
  2. Help: rear end alignment issues
    By godless-phoenix in forum Suspension and Handling
    Last Post: 12-02-2011, 03:57 PM
  3. rear end alignment Q:
    By xmarkx in forum Suspension and Handling
    Last Post: 10-27-2010, 01:29 PM
  4. Replies: 13
    Last Post: 07-08-2007, 09:42 AM
