    long and strong Willfully Armed's Avatar
    Olathe, KS
    01 WS6 (stock)
    left rear ABS speed sensor for 01 WS6 A4 W/ trac
    Don't want to order one online just to find out it's not actually the problem, would rather just try a cheap used one first
    01/06 FFL
    www.midwestguntrader.comIts FREE!
    Olathe, KS
    01 WS6 (stock)
    Bump to top.
    Apparently seeking a unicorn egg...
    1 (100%)
    I would hit the local parts store and plug in their brake code scanner. It'll tell you which sensor (if any) is acting up. Also, have you looked back there to confirm that the harness is plugged into the sensor and that the pins are not bent? Last ABS light I had was just an unplugged sensor on our Suburban I had knocked loose while working on something else.
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    If you have a scanner which reads ABS, you can also monitor the speed at each wheel to determine which sensor is faulty, if any. That's how I found out my right rear one had went bad.
    Olathe, KS
    01 WS6 (stock)
    Left rear reads 0 mph. Connections are clean and solid.
    I'd guess the sensor is bad then, assuming the car was in motion when you took the reading lol.
    Olathe, KS
    01 WS6 (stock)
    Still looking.GM*10456535*Sensor/ALS318. I'd gladly try a used one
    1 (100%)
    My guess would be that they probably used that same sensor on all sorts of vehicles from around that time period. Boneyard?
  1. O2 sensors voltage low bank1 rear left
    By Durango in forum General Help
    Last Post: 04-23-2009, 07:24 PM
  2. Left rear rattle
    By Fred H. in forum Convertible
    Last Post: 05-17-2008, 02:21 PM
  3. Slow speed thump/rattle from left rear
    By Fred H. in forum Suspension and Handling
    Last Post: 05-17-2008, 01:32 PM
  4. squeeky rear when cornering left...?
    By grandkodiak in forum LT1
    Last Post: 05-03-2008, 05:18 PM
  5. Replies: 1
    Last Post: 06-19-2007, 07:06 PM
