Results 1 to 3 of 3
    BLKHWK Durango's Avatar
    New Brunswick Canada
    BLK TA modded 12.2@113mph
    O2 sensors voltage low bank1 rear left
    That was the reading on the machine that I was given today and the mechanic tells me It could be wiring related..... Have you heard of that before?
    Is an NGK model o2 sensor good quality?
    Expensive at $142.00 Cnd. I hope that they don't all let go. Are they hard to change they are charging me 1 hour labour if everything goes well It seems pretty darn easy to me to change looking at it anyway.
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    bosch 50 bucks work fine on both primary banks for me. If you have headers check to make sure you didn't burn a wire lead to the O2's
    Quote Originally Posted by JaycenK View Post
    thanks Bosh is $105 here I'll check I did warm it up a bit:0
  1. Delete Rear O2 Sensors?
    By Speed Bump in forum General Help
    Last Post: 09-21-2009, 09:36 AM
  2. Left rear rattle
    By Fred H. in forum Convertible
    Last Post: 05-17-2008, 02:21 PM
  3. squeeky rear when cornering left...?
    By grandkodiak in forum LT1
    Last Post: 05-03-2008, 05:18 PM
  4. turning off rear o2 sensors
    By big hammer in forum Computer & Tuning
    Last Post: 04-30-2008, 11:14 AM
  5. Front 02 sensors same as rear?
    By sunsetorangess in forum External Engine
    Last Post: 03-17-2006, 07:41 PM
