    Bragg NC
    Met. Sunset Orange
    01 SS
    Front 02 sensors same as rear?
    I was gonna swap my rear 02 sensors with my front 02 sensors, are they the same? They have the same part number if you purchase them from autozone but i was curious if anyone knows for sure.
    thanks
    J
    Member snake_skinner00's Avatar
    KY
    Mystic Teal
    2000 Z28
    i dont think they are, but dont hold me to it. i'm sure somebody will reply with a positive answer.
    near St. Louis
    navy blue
    2002 Z-28 Camaro M6
    If they have the same part number they are the same. To be safe though I would check at a different parts supplier. They serve different functions but I suppose they can be constructed the same. Why switch them ?
    Member adham's Avatar
    Newport News, VA
    2000 Pontiac Trans Am
    yes they r the same, i just got new ones
    Bragg NC
    Met. Sunset Orange
    01 SS
    just put in my pacesetter lt and i spliced the wires together and now im throwin all kinds of 02 sensor codes so i ordered extensions and i was gonna use the rear sensors and put them in the front bc the fornt ones are spliced. i do have rear 02 sims in place but a guy i know hooked my car to his comp and he said its not getttin a high reading to the comp so its pissin the comp off to throw codes.
    gotta start somewhere to fix the problem, so its new 02's and extensions and reset and see what happens
    Newport News, VA
    the rear o2 sensors should and will work in front
    now if they are bad, its a different story
    my car has over 100,000 miles on it therefore it needed new ones
    i just got mine 2 days ago
    i just replaced the ones in the front because the ones in the back are not important
    Bragg NC
    Met. Sunset Orange
    01 SS
    car only has 10 thousand miles on it so i should be good, lol
    i just wanna get the beast runnin right again, wanna hit the track with the new parts on there
    Roseville, CA
    05 Wrangler
    00 Z28 sold :-(
    Quote Originally Posted by adham
    Bragg NC
    Met. Sunset Orange
    01 SS
    for info purpose's the rear 02's will work in the front,they are the same, and so far so good my check engine blue's are over
    replaced the front 02's i think the headers blue them out, or it was a crappy wiring job not sure which one but i put new 02's in and used harness extensions and so far so good
    thanks for yall's input
    J
    Ohio
    2002 WS6 Trans Am
    The local Pontiac parts dealer is a buddy of mine and he looked up the o2 part numbers for me the driver side rear is the same as the two front and the passenger side rear is a different part number. If you get the o2 from autozone or one of the other aftermarket companies they are all the same.
    Roseville, CA
    05 Wrangler
    00 Z28 sold :-(
    Quote Originally Posted by WS6TNT2K2
    might be because of the length of the sensor wire....but the actual sensors are the same.
    Bragg NC
    Met. Sunset Orange
    01 SS
    All i know is the part numbers on the sensors are the same and they seem to work just fine up front, so id assume there the same.
    so far so good
    thanks for yalls input
    J
  1. Front o2 sensors
    By One_Bad_TA in forum External Engine
    Last Post: 02-13-2009, 09:11 PM
  2. FS: Stock Front 02 sensors out of my 2002
    By xtremevette in forum Parts Wanted / Trade
    Last Post: 05-15-2008, 07:21 AM
  3. turning off rear o2 sensors
    By big hammer in forum Computer & Tuning
    Last Post: 04-30-2008, 11:14 AM
  4. front o2 sensors for 98z
    By LETHALxLS1 in forum Parts Wanted / Trade
    Last Post: 07-23-2007, 06:28 AM
