Results 1 to 20 of 23
05-09-2008, 05:28 AM #1
- Apr 2008
- Ft Worth
Green- 94 TA GT
Slow speed thump/rattle from left rear (FOUND!)
I am trying to chase down what I believe is a suspension noise coming from the left rear of my car. I only hear it at slow speeds when I hit small and meduim sized bumps. It almost sounds like a loose shock mount, but I checked them and they are fine.
Has anyone else seen this problem and found the cause?Last edited by Fred H.; 05-17-2008 at 02:34 PM.
05-09-2008, 06:29 AM #2
05-10-2008, 03:20 PM #3
check the trailing arms.
05-11-2008, 08:31 AM #4
if you have SFC's check those i was getting the same noise and one of the bolts was loose causing the rattling noise
05-11-2008, 11:13 AM #5
same problem here as well. I cant figure out what it is either, Its mighty annoying though! but yes it does sound like a loose shock mount.
05-12-2008, 05:05 AM #6
05-12-2008, 11:30 AM #7
subframe connector
05-12-2008, 11:48 AM #8
thank you figured it out after I sent it Don't have any the turbo inlet tube acts as one on driverside but none on passenger side. have shaken everything to the point of almost ripping it off the lift but can't find it. Only noticable at idle or barely any gas on ruf surfac eis not noticable at speed.
05-12-2008, 03:08 PM #9
- Apr 2008
- Ft Worth
Green- 94 TA GT
If it makes you feel any better, I am still looking for mine too. It sure sounds like it is coming from the rear shock mount, but I can't find anything loose. I even went in and tightened everything I could, but still have the noise.
I can only hear it at low speeds over small bumps. Larger bumps don't make the noise, only small ones. It sounds like a metal on metal low frequency thump. Maybe it's the spring hitting something. I have removed the wheel, checked the exhaust, brakes, put the car on a lift, and had it to a suspension shop. Still can't find the culprit.
05-12-2008, 08:59 PM #10
^^ perfect description, bought my car about 6 months ago, after the first month it started doing it and i still cant find it. Ive done all the same stuff and just cant find it.
05-13-2008, 03:00 AM #11
- Nov 2005
- Georgia
SUNSET ORANGE- 2001 CAMARO SS
My 01 SS has had a clunk or rattle in it since new. I notice it when I ease through a rough parking lot or rough or uneven ground. I recently grabbed the rear wheel and shook it and heard the noise. I checked the lug nuts..they were tight. I then removed the wheel and noticed that I have a tiny bit of in-out axle play. The brake pads and or calipers is where most of the clunking is coming from though.
05-13-2008, 05:36 AM #12
- Apr 2008
- Ft Worth
Green- 94 TA GT
I had both axles replaced and the entire rear end rebuilt with new wheel bearings, carrier bearings, and pinion bearings last week. No change in the noise. I don't believe it is the brakes or wheels or rear end or drive train. I am convinced it is a suspension noise.
05-13-2008, 12:44 PM #13
- Oct 2006
- St. Clair Shores. Michigan
I had a similar noise on mine awhile back and it ended up being the coils were out of orientation. the Lower pigtails were supposed to face the front of the car and they were facing each other. Best I can figure is they twisted over time, once I adjusted them the noise was gone.
Might be something for you guys to look at.Craig
Semi Retired Street Racer
Gone but not forgoten
NBM `98 Formula M6 HdTp
1 of 1 Build Date 3/12/98
05-14-2008, 03:54 AM #14
- Apr 2008
- Ft Worth
Green- 94 TA GT
Well, it definetly is something in the left rear suspension. I removed the left sway bar bushing and coated the inside of it with candle wax to stop a squeak and reinstalled it. Now my "clunk" is happening all the time on almost every bump at any speed. So making the sway bar more free to move, has made the problem worse.
05-14-2008, 05:40 AM #15
05-14-2008, 09:19 AM #16
Ok, I've have had this problem twice and was 2 seperate issues. First time it was the weld broke on the lower control arm and there was play in the bolt. Second time, took awhile to figure out, I finally went to a lift and after a hour of tightening every bolt under the car, it was the left side of the panhard bar bolt was slightly loose. When the panhard bar was loose, the rear of the car felt like it had a little bit more side to side movement.
05-14-2008, 09:34 AM #17
- Apr 2008
- Ft Worth
Green- 94 TA GT
I have no panhard bar or sub frame connectors installed. The only thing that has been done is the rear shocks on the car have been changed at some point in it's life, and I have a strut tower bar under the hood.
I am going to check the pigtails on the springs tonight and see how they are oriented. Maybe my piggies are headed in the wrong direction.
05-14-2008, 04:33 PM #18
- Apr 2008
- Ft Worth
Green- 94 TA GT
I think I am getting closer to nailing down the culprit. I took off the left rear wheel and checked the pig tails, and the ends of them were pointing forward, so I left them alone. I used a large rubber mallet and began tapping some of the suspension components. The link arm that connects to the the frame on one end and the rear axle on the other, appears to have some side to side slop in it. I can tap it and move it left and right at both pivot points almost an inch. Seems like it isn't a real great design of the joint. I tapped it into the center-most position and then put the wheel back on and drove the car, and the noise seems to have nearly gone away. So now I am thinking it is coming from the attach point where the arm attaches to the frame of the car. I may just go ahead and replace all the bushings on it and see if that fixes it.
05-15-2008, 05:30 AM #19
05-15-2008, 06:56 AM #20
I have the same damn problem but its on the right side. I've checked everything checked for loose bolts even removed my catback thinking that was the problem. Mine almost sounds like the subframe connector is slaping against the frame but i've checked and rechecke those bolts. I've pretty much given up untill the day I get the motivation to just remove everything and reinstall it.
Wanted: left rear ABS speed sensor for 01 WS6 A4 W/ trac
By Willfully Armed in forum Parts Wanted / TradeReplies: 7Last Post: 05-05-2016, 03:06 AM -
Suspension Rattle At Slow Speed
By knappbunch in forum Camaro / SSReplies: 1Last Post: 08-14-2008, 02:36 PM -
Left rear rattle
By Fred H. in forum ConvertibleReplies: 17Last Post: 05-17-2008, 02:21 PM -
Rattle during low speed sharp turns?
By Midnight02 in forum DrivetrainReplies: 0Last Post: 02-21-2007, 09:54 AM -
Rear End Thump??? Wheel Hop.
By Pro50gt in forum Firebird / WS6Replies: 4Last Post: 11-21-2006, 05:50 PM
