    May 2008
    phoenix, az
    99 trans am
    clunking noise from underneath the car
    so i have a 99 T/A automatic and recently i have been hearing this clunk when i stop and i can feel the tranny kind of "slam" into gear going from park to reverse and then into drive i am the second owner of the car and it has 135,000 miles on it and im not sure what the previous owner did to it or rather didn't do. so if anyone has an idea of what it might be and a cost estimate as i am pretty broke just got out of the air force and got married two weeks ago.
    Austin, Tx
    Black/Black
    2000 Trans Am WS6 A4
    It's one of three things... I'll list them in order of most probable, to not...
    1) It's your tranny mount... even if a shop has inspected it, they can miss a worn spot.
    2) U-joints...
    3) Motor mounts...
    Our cars rip tranny mounts pretty easily...
    May 2008
    phoenix, az
    99 trans am
    how hard is it to fix one on your own and or how expensive
    MEMBER 5150's Avatar
    Visalia Cali
    SILVER
    2000 Z/28
    It could also be a worn out rearend. To much backlash.
    Austin, Tx
    Black/Black
    If I had to guess, it's the tranny mount...
    I have never done the mount, as I have no time for that, but I have done the U-Joint on similar cars... you just unbolt the driveshaft from the rear-end, and slide she shaft out. Take it to your local machine shop for them to replace the joints... Something like $20, and about an hour.
    If you feel the clunk near your feet, it's your mount, and I can't comment on how easy it is to replace. I assume you just need a tranny jack and less than an hour of time on your hands--but again, I've never done it before.
    The tranny mount will run you about $25 and takes less than an hour to swap, its fairly easy.
    Painted manta stripe
    Poway, Ca
    SOM
    2001 Z28 (Sara)
    I had one of my aftermarket LCA bolts loosen, which caused a clunk when I accelerated and deaccelerated, I tightened the bolts and the clunk went away.
    SteveC
    Austin, Tx
    Black/Black
    Get a poly mount if you can... they will last considerably longer...
  1. Clunking /rattle noise
    By xenergyx in forum General Help
    Last Post: 11-05-2014, 05:32 PM
  2. Clunking/Rattling Noise in my T/A
    By Caelynne1724 in forum General Help
    Last Post: 04-14-2011, 05:59 PM
  3. clunking noise coming from rear?
    By stew215 in forum General Help
    Last Post: 08-21-2010, 07:18 AM
  4. Drivetrain clunking noise
    By mpowell04 in forum Manual Transmission
    Last Post: 04-24-2007, 01:38 PM
  5. Pinging noise from underneath car
    By Drks1de in forum General Help
    Last Post: 07-01-2006, 09:10 AM
