Thread: clunking noise coming from rear?
08-12-2010, 12:05 PM #1
So today my car started to make this awful clunking noise while turning. Kind of sounds like someone is hitting the bottom of the car with a hammer. This noise only happens while I am turning. I did just put on SFC the other week and I torqed them down to the recomended amount. What do you guys think the problem could be?
08-12-2010, 12:32 PM #2Exalted Cyclops
- Feb 2007
- San Diego, CA
When was they last time you checked the diff gear lube?
If never then try that 1st and add posi additive. It might be the clutch plates in the posi sticking.67 Camaro: K-K + 797-z (look it up), 454/Th400/4.10 12-bolt = 6mpg, PS/PDB/PW tilt, tach, gauges...
Carbon footprint? CLOWN SHOE!
08-12-2010, 12:55 PM #3
I just refilled the diff like 2 months ago when I changed out my axle bearing.
08-16-2010, 02:47 PM #4
well I finally had time to tear the cover back off the rear again and its gone. The magnet was covered and there was metal shavings all over. All the gears looked fine until I noticed the spider gears look like they are chewing through the side of the housing that holds them in. I will have pics posted later.
I got hold of a local fbody scrap yard and I am picking up a complete 3.42 rear.
Will i need to do anything for this rear to fit in? I now have 2.73 gears
08-21-2010, 07:18 AM #5Import Killer
- Sep 2005
- MIchigan
Navy Blue Metallic- 2000 Camaro SS
nope should be good as long as its the same carrier brand (torsen, auburn) other wise may set an abs light depending if you has acs or not.
Clunking coming from rear
By jcws6 in forum DrivetrainReplies: 27Last Post: 09-23-2008, 01:14 PM -
noise coming from rear end?!?!
By martinez_z28 in forum DrivetrainReplies: 7Last Post: 07-03-2008, 04:57 PM -
Question: Sueaking noise coming from rear
By GetSome04 in forum GTOReplies: 2Last Post: 06-10-2008, 07:32 AM -
road noise coming from the rear
By barryz in forum General HelpReplies: 12Last Post: 02-13-2008, 08:23 AM -
Driving home all of a sudden clunking noise... BRoKEN REAR KYB ADJ shock!
By eddielb in forum Suspension and HandlingReplies: 12Last Post: 05-04-2007, 10:57 PM
