Results 1 to 3 of 3
    HUGH JARDON GetSome04's Avatar
    Chicago, IL
    QUICKMFNSILVER
    2004 GTO
    Sueaking noise coming from rear
    When driving a squeking noise is coming from the rear tires, it stops when i press the brakes. I got new brake pads about two months ago so i know they are not worn down. It sounds like the squeak it would make from worn down brake pads but i checked them and its not that. I took it in to where they replaced my pads and they said they couldn't find anything wrong and started talking that my rotors are just about at spec maybe lower and they could replace them all, but they never even took off my rear tires while it was on the lift?? I have 64k miles on my car and no mods to the tires or suspension. I guess im just looking for other possible reasons this squeak would be happening? its not loud but its annoying the french toast outta me
    Member Z28collection's Avatar
    chapin,s.c.
    black silver
    99 z28, 81 z28
    brakes
    ive done a lot of brake jobs over the years, and with the materials they use on pads today they do make a lot of noise. one thing i used to do to all my brake jobs is bevel the edge of the brake pads. this would usually help with the slight squeal. also if they turned the rotors ive seen mechanics not cut far enough into the center of the rotor and the edge rides on the pad and can cause a squeal. just some things to look at and good luck.
    mercersburg pa
    hugger orange
    2004
    also might want to check your parking break shoes. they are shoes in the center of your rear rotor, they are small, doubt if they are worn, but might need an adjustment
  1. clunking noise coming from rear?
    By stew215 in forum General Help
    Last Post: 08-21-2010, 07:18 AM
  2. Very Loud noise coming from trans or rear-end?
    By greenvilleTA in forum Drivetrain
    Last Post: 10-04-2008, 10:14 PM
  3. noise coming from rear end?!?!
    By martinez_z28 in forum Drivetrain
    Last Post: 07-03-2008, 04:57 PM
  4. road noise coming from the rear
    By barryz in forum General Help
    Last Post: 02-13-2008, 08:23 AM
  5. noise coming from rear end of car, confuses me
    By Matto4785 in forum Drivetrain
    Last Post: 09-26-2005, 07:45 AM
