    Feb 2014
    Florida
    2002 pontiac trans am WS6
    Clunking /rattle noise
    Okay I had a lil trouble labeling this topic....I have an 02 trans am ws6 with a 4l60e trans I have just completed changing the fluid in it as well as changing the filter. After I was done I let it idle and warm up and than cycled each through the gears at idle each for a few mins and than took it for a test drive everything was fine. Later in the evening I took it out for a longer ride as I was waiting in a drive thru I heard a faint metallic clunking/rattling but its only really audible in the car in park and neutral. Does anyone know what this might be ?
    Check your engine and transmission mounts.
    I assume you checked the fluid level after the change? With the transmission up to temp, the engine running and and the car parked on a level surface, slowly cycle through each gear and then once back in park pull the dipstick to check the level.
    Feb 2014
    Florida
    Yes i checked the fluid after it was up to temp and cycle each gear for abt 2 mins....and the trans mount has been replaced once i did check it before i took the car off the stands it was still in good condition....any other ideas .....if its a cracked flexplate how can i inspect it without taking it out of the car?
    Feb 2014
    Florida
    here is a video of the noise
    Your best access to the flexplate is to pull the starter. You can then roll the engine over using a breaker bar and a socket on the balancer bolt. If it turns out you do need a flexplate, I have our stock one setting in my lower garage awaiting a new home.
    Any chance you bumped the exhaust while working on the transmission and moved something?
    Feb 2014
    Florida
    I think it might be that catalytic converter on the pass side so i plan to take it off and check inside it after it cools down in an hour or so....and the only reason is cause i found a video where someone had the same sound...*crossing fingers*
    Very well could be the issue.
  1. Question: bad clunking noise after lcas installation
    By torker in forum General Help
    Last Post: 11-17-2011, 03:27 PM
  2. Clunking/Rattling Noise in my T/A
    By Caelynne1724 in forum General Help
    Last Post: 04-14-2011, 05:59 PM
  3. Help: clunking noise from underneath the car
    By bperk in forum Automatic Transmission
    Last Post: 05-10-2008, 10:07 AM
  4. Help: Clunking/rattling noise from driverside?
    By bgable in forum General Help
    Last Post: 04-20-2008, 06:55 AM
  5. Drivetrain clunking noise
    By mpowell04 in forum Manual Transmission
    Last Post: 04-24-2007, 01:38 PM
