    St. Louis, MO
    1999 Pontiac
    Drivetrain clunking noise
    i just had my clutch replaced, picked up my car ('99 M6 T/A) last night and all seemed fine. on the way into work today, i noticed a loud clunking noise when i shifted, which progressively got worse and became constant even with the car in gear. any idea what this possibly could be? hopefully it is something they screwed up and will fix on their dime. i really don't feel like shelling out any more $$$$.
    georgia
    1998 pontiac trans am
    Quote Originally Posted by mpowell04 View Post
    any noises before the clutch was replaced like what you described? any noises with it out of gear? make sure they didnt leave anything loose underneath.
    St. Louis, MO
    1999 Pontiac
    there were noises (throwout bearing??), but nothing like this. i'm hoping (and assuming) that they left something loose or screwed something up on the install.
    georgia
    let us know what you find out.
    San Diego
    1996 Pontiac Trans Am WS6
    Torque arm
    Check out the torque arm where its bolted to the rear end. I once forgot to tighten the bolts after an clutch replacement. When ever there is push or pull applied to the torque arm you will hear a "clonk".
    Just an Idea. But let me know.
    Quote Originally Posted by GolfLT1 View Post
    Good suggestion, they possibly didn't get the torque seated well and its loose where it bolts to the tranny or its hitting the driveshaft. I would check all with the driveshaft and torque arm to make sure both of them are tightened down. If its not either of those, get it back to the shop.
    Painted manta stripe
  1. Clunking /rattle noise
    By xenergyx in forum General Help
    Last Post: 11-05-2014, 05:32 PM
  2. Help: clunking noise from underneath the car
    By bperk in forum Automatic Transmission
    Last Post: 05-10-2008, 10:07 AM
  3. New Clunking Sound from Drivetrain
    By Rhinohuey in forum Drivetrain
    Last Post: 11-21-2007, 09:42 AM
  4. New Clunking Sound from Drivetrain
    By Rhinohuey in forum Manual Transmission
    Last Post: 11-20-2007, 01:52 PM
  5. Replies: 1
    Last Post: 04-28-2007, 06:03 PM
