Results 1 to 1 of 1
11-20-2007, 01:52 PM #1
New Clunking Sound from Drivetrain
Whenever I am cruising along in 1st gear and I start to pulsate the gas pedal, and the car starts to lurch back and forth, I get a really strange clunking sound coming from somewhere near the transmission. It almost seems to be coming from inside the transmission. It just sounds just like I have alot of play in the joint between the transmsission and the driveshaft (don't know what its called...universal joint or CV joint) but I got underneath the car and tried to turn the driveshaft and only got a very small amount of play.
Today I jacked up the rear of the car and put the transmission in 1st and had someone rotate one of the back wheels forward back forward back... really quickly while I was under the car. I hear what sounds like the same noise coming from inside the transmission. Everytime they switch direction while rotating the wheel I got a clunk.
I also get the same noise when I am cruising in first gear at ~1600-1700 rpms and a push the clutch in quickly to take it out of gear. Its the same noise coming from the same place except instead of making just one clunk it makes like 4 or 5 (like a loud rattling sound).
Also, I'm not sure if this could be related to the problem, but when I am in first gear, moving, and I put in the clutch just to take it out of gear it feels like it sticks in the 1st gear position for just a second. When I am still rolling and I go to put it it 1st gear from neutral it takes a second for the shifter to slip into the 1st position. (If I push the shifter towards 1st, it sits in between N and 1 for a second then it slips into 1st after the car rolls for just a second.)
Anybody have any idea what could be causing the noise? I am about to go crazy.
Question: Clunking sound on hard take off
By burning tires in forum General HelpReplies: 21Last Post: 10-12-2011, 12:39 PM -
By Rhinohuey in forum DrivetrainReplies: 7Last Post: 11-21-2007, 09:42 AM -
clunking sound
By dlmeadows in forum General HelpReplies: 0Last Post: 09-22-2007, 03:39 PM -
Drivetrain Clunking or banging with weight in car
By Hanman in forum DrivetrainReplies: 1Last Post: 04-28-2007, 06:03 PM -
Drivetrain clunking noise
By mpowell04 in forum Manual TransmissionReplies: 5Last Post: 04-24-2007, 01:38 PM
