Results 1 to 20 of 22
    Aug 2011
    Detroit
    1998 Camaro SS
    Clunking sound on hard take off
    i have a 1998 cama ss and ive bought it back in september for 1000 due to body work and now im jst taking it for a drive after being revived for being dead in a back yard for 8 years lol i drove it and it rides great suprisingly lol but i have one consern with it... i did a half open throttle at 25 and she took off but as she was taking off there is a cluncking sound in the rear somewhere and i can't figure out wut it is i was woundering if anyone would have sometype of idea of what it would be? (o yeah it was front end dammage not rear)
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Could be the rear end itself. 10 bolts are weak and notorious for going out. Could be the suspension binding. Could be the exhaust is loose and hitting something. Could be a broken torque arm or loose torque arm. Could be excessive play in the drive train, specifically the driveshaft. Could be a lot of things really.
    I'd start with the cheapest and easiest.
    Aug 2011
    Detroit
    1998 Camaro SS
    aight thanx ill give all those a look out
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    Get it on a lift with a buddy in the car and start checking off things that do not make the noise. If I would have to guess I would say the rear is the culprit. Just a guess.
    Another thing that just popped into my mind is wheel hop...since you said on hard take off's.
    Senior Member Lunatikgixxer's Avatar
    Mar 2010
    St Pete, FL
    Bat mobile black
    2000 Trans am WS6 M6
    wheel hop only really happens when you spin and i dont think he was doing that with half throttle, just saying. Id say start with the torque arm, you said its been sitting forever so im sure its the stock torque arm and its probably broke. Jack it up and take a look.
    Guess it would depend on the amount of tread left on 13 year old tires
    Apr 2010
    hawaii
    2001 camaro ss
    id grab ahold of the drive shaft and see how much play there is. Could just be a 15 $ U-joint.
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    Keep us posted.
    Mar 2010
    St Pete, FL
    Bat mobile black
    yes i agree BUT since it was sitting for so long then therefore it was not driven so no tread could possibly wear off!
    COTM July '09
    Annapolis, MD
    BLK/BLK w/CGM Stripes
    2010 Camaro 2SS/M6
    Transmission mount?
    Could be excessive play in the diff too. See how much play you have when you rotate the driveshaft. I used to have that issue on mine and when the ring gear lines up just right, it'll make a clunk when I take off.
    I like work. It fascinates me. I can sit and look at it for hours.
    My Cardomain Site My Fquick site Custom Installs
    Aug 2011
    Detroit
    1998 Camaro SS
    naw lol i scrapped those tires and bought some good years right be fore i drove it
    could be a few different things... i'd check your TQ arm (i snapped mine in half and had a clunk)... i'd check the trans mount as well (you probably can see the shifter move up and down under hard acceleration)...
    Mar 2010
    St Pete, FL
    Bat mobile black
    I just thought of something.. If your torque arm is broken then its throwing off the pinion angle a little and you might hear a whinning noise.. Do you hear that? If you do then you can probably say its the torque arm.
    Aug 2011
    Detroit
    1998 Camaro SS
    alright well heres my update to that problem i got it in the air now as we speak and im checking out the torque arm and im cleaning off all the gunk and dirt from it onlt to find out that thats the newest part under the car.the T-arm isnt rusted out and infact looks like its only a couple days old. soo i went to check the play in the drive shaft there isnt any thats still solid so then i went to there the trans sits at only to find where the T-Arm starts at where the transmission is has excessive play inside where it sits at inside its's bushing. i can litterally take my arm and push the T-arm up and down the bushings wore out could that be it?
    I would say yes.
    NC
    1998Z28
    I sure hope you checked your gear grease level and put in a bottle of GM antislip while your at it. Thats along time sitting and even a slow leak would have left you high and dry by now.
    TSP 347 SB, TSP Stage 2.5 PRC LS6, TSP MS4, Performabuilt Stage 2 4L60E, Yank PT4000, 4.11s, Fast 90/90, FTRA Cold air intake+all the free mods, Dynatech Supermaxx Exaust System, DMH Cutouts, Hooker Catback/FTRA Tips. Tuned by RPM/Garner NC. 11.28@119
    North Jersey
    2004 GTO M6
    Replace the torque arm bushings and let us know if the clunk has ceased and if you need anything else.
    Aug 2011
    Detroit
    1998 Camaro SS
    alright you guys im back on that update to that problem srry it took soo long for me to get back but the problem was a transmission mount and i replaced it and drove it and the hard clunkings gone now... so now all i have to get to complete the car is a pass. fender pass. fog light assembly headlights and a windshield and the camaros done lol
    Glad you got her fixed up!!
  1. New Clunking Sound from Drivetrain
    By Rhinohuey in forum Drivetrain
    Last Post: 11-21-2007, 09:42 AM
  2. New Clunking Sound from Drivetrain
    By Rhinohuey in forum Manual Transmission
    Last Post: 11-20-2007, 01:52 PM
  3. clunking sound
    By dlmeadows in forum General Help
    Last Post: 09-22-2007, 03:39 PM
  4. Huge clunking sound.....
    By clg82 in forum Firebird / WS6
    Last Post: 05-12-2007, 07:38 PM
  5. clunking sound coming from behind the tranny
    By ninobrn99 in forum General Help
    Last Post: 08-12-2005, 08:14 PM
