    Senior Member ninobrn99's Avatar
    Aug 2003
    Honolulu HI
    all bore 370 Trans Am
    Angry clunking sound coming from behind the tranny
    ok, heres the symptoms:
    when in stop and go traffic if i get the car in 2nd and have to push the clutch in, i hear a clunking sound.
    when im at a stop and start to go straight or on some turns one of the tires chirp. when taking a turn it kinda feels like the rear end is moving a bit more than it should. i have the following suspension upgrades: lca's, phb, non tranny mounted TA, relocation brackets, stock driveshaft and just installed a new clutch about 2wks ago. any ideas what you guys think it could be.
    it kinda seems like when im in the traffic situation and i push the clutch in, it feels like its a front and back type of clunk not rotational, but it happens when i shift.
    I escaped DC
    Anchorage, AK
    Might be the tranny mount. You can get an Energy Suspension one at Advance, Autozone, etc right off the shelf. It's a fairly easy install, too.
    Dec 2002
    n/w chicago
    2000 nhra edition formula
    i wanna say tranny mount
    EL PASO TX.
    RED
    1998 CAMARO Z28
    Cool
    Check The Plastic That Holds The Control Arm I Had The Same Problem
    Hope It Helps
    tommyz28
    Guest
    Just had this problem, check the bolts under the diff that hold the "tranny to rear end support bar" not sure what thats called and its too late to check.
  1. Clunking sound coming from driver's side
    By 98TransAmWs-6 in forum General Help
    Last Post: 03-30-2011, 10:21 AM
  2. clunking noise coming from rear?
    By stew215 in forum General Help
    Last Post: 08-21-2010, 07:18 AM
  3. Clunking coming from rear
    By jcws6 in forum Drivetrain
    Last Post: 09-23-2008, 01:14 PM
  4. New Clunking Sound from Drivetrain
    By Rhinohuey in forum Drivetrain
    Last Post: 11-21-2007, 09:42 AM
  5. clunking sound
    By dlmeadows in forum General Help
    Last Post: 09-22-2007, 03:39 PM
