Results 1 to 20 of 24
03-24-2011, 09:53 AM #1Senior Member
- Apr 2010
- Alabama
Clunking sound coming from driver's side
Yesterday I took off my front calipers to clean them and also bled the brakes. Now when I am driving I hear this clunking soud and feel a vibration on the brake and gas pedal. Could this just be that the caliper needs to be re-adjusted? Any suggestions would be great.
03-24-2011, 10:09 AM #2Junior Member
- Sep 2006
- Georgia
red black- 98Z28
Sounds like a sticking caliper pin. Need to clean and relube them.........
03-24-2011, 10:36 AM #3
03-24-2011, 10:41 AM #4
03-24-2011, 11:28 AM #5Senior Member
- Mar 2007
- Henryetta/Tulsa Oklahoma
Yes, anti-seize compound. I have been through two caliper brackets before I realized grease isn't good enough.....
My dad has Caterpillar anti-seize compound for heavy equipment. Stuff is pretty awesome. I've checked the fronts twice to be sure, all is well.
03-24-2011, 12:46 PM #6
03-24-2011, 07:01 PM #7Senior Member
- Apr 2007
- Newport, RI
Navy Blue Metallic- '00 Formy A4
There's actually a special grease for that purpose. I bought a tube at NAPA last year, I think it was like 5 bucks.
I'm sure antisize would work too, but antisieze isn't really a grease. I can see it getting all gummed up in something that's supposed to move.
03-24-2011, 08:18 PM #8
when you go to the autoparts they will have little packets of caliper brake pin grease. I will buy one packet per side. Pull the caliper out, the pins are were the rubber bushings are. grab the pin and pull it out with the rubber bushing. clean the pin out and use some brake cleaner inside the pin hole to clean all the old stuff out. use napkins or rags to clean left over grease.
Put new grease in the hole and lube the pin. Put the pin back with it's rubber bushing and put back the caliper. The grease is cheap.
03-25-2011, 10:24 AM #9Senior Member
- Apr 2010
- Alabama
Well I lubed the pins and the vibration is still slightly there and so is the sound. Is there anything else that could cause this? Would a bubble in the brake line cause this vibration and sound?
03-26-2011, 03:18 PM #10Senior Member
- Apr 2008
- Madison, WI
warped rotors??
03-28-2011, 06:26 AM #11Senior Member
- Mar 2007
^^ Maybe this, our cars are notorious for it...
03-28-2011, 08:14 AM #12
wrapped rotor or you can have a bad hub.
03-28-2011, 09:50 PM #13
03-29-2011, 01:38 AM #14
it sounds like the caliper bracket itself may not have been tightened enough. usually they get put back on during a brake job with an impact gun so if that was not used or decent size ratchet it could be the case. the caliper is not the part that takes the braking loads, the caliper bracket where the pads sit is. another reason for clunking on braking could be that the brake pads themselves are sitting in the bracket too loose. this is usually caused by removing any rust or corrosion from the ends of the pads to free them up. the result is play on either end of the pad and when the brakes are applied it causes the pad to slam into the bracket making the clunking noise.
03-29-2011, 03:16 AM #15
03-29-2011, 06:07 AM #16Senior Member
- Apr 2010
- Alabama
03-29-2011, 06:46 AM #17Electrical Engineer
- Jul 2009
- North of the Motorcity
Torque specs for the brakes:
Front caliper guide pins 23 ft/lbs
When you jack your car up, try to push and pull on the whole wheel. By that I mean, push the top of the wheel towards the motor and simultaneously pull the bottom towards you, then reverse. See if you have any play in the wheel.
The vibration, is it only happening when you brake? Or all the time?
03-29-2011, 09:51 AM #18
03-29-2011, 10:18 AM #19
I think what KMdef9 was getting at and what is very possible is your wheel bearing/hub is worn out. when that happens the rotor leans and pushes the pads in a lil so when you hit the brakes they have to move a little bit further than normal before they begin to stop the vehicle. does the car pull at all when braking. this is also a give away of a loose bearing/hub.
03-29-2011, 12:45 PM #20
Help: Rear end noise! side to side clunking sound..C-clips broken?
By DaytonaBlues in forum DrivetrainReplies: 12Last Post: 11-14-2012, 02:30 PM -
help front end drivers side clunking sound
By wands in forum Suspension and HandlingReplies: 18Last Post: 01-13-2012, 04:09 AM -
clunking sound driver side rear, any advice?
By JAGUAR5822 in forum Suspension and HandlingReplies: 30Last Post: 12-21-2008, 08:09 AM -
thumping sound in the back sounds like it is coming from driver side.
By dafaic in forum LT1Replies: 2Last Post: 11-24-2006, 07:36 PM -
clunking sound coming from behind the tranny
By ninobrn99 in forum General HelpReplies: 4Last Post: 08-12-2005, 08:14 PM
