    goFaSSt
    Tucson
    1999 camaro ss
    How do I remove pcm?
    just got pacesetter ceramic headers and ORY. Have FRA, K and N, High flow lid, port n polish MAF, Port n polish TB, Tb fluid relocation thing, and exhaust cutout. Everything was fine untill the headers and Y pipe because of the o2 sensors. So I am going to send the PCM to LSX tuiner. Any where i could find instructions on how to safely remove the PCM to send it to them? also any HP estimates? 99 ss m6. any bottle necks in my mod list? basically just looking for airflow stuff at the moment. but open to all suggestions.
    thanks guys. and girls.
    Senior Member
    Jacksonville, FL
    I removed mine to get wires through the grommet under it. I just disconnected the battery, loosened the bolt on each connector (doesn't have to come all the way out), then unplugged the connectors and pulled it out.
    goFaSSt
    Tucson
    1999 camaro ss
    hex bolt right? do you know what size?
    goFaSSt
    Tucson
    1999 camaro ss
    niiiice. your the man!
    NW Chitown
    2002 WS6
    Be sure to pay SPECIAL attention to getting the rubber gaskets seated correctly when you reconnect the PCM to the two harnesses. Quite a bit of water can and will get in there if those gaskets aren't seated and will wreak havoc on things! I learned first hand...
    | '02 WS6 M6 | KOOKS/ORY | LC-1 | LOU'S SS | UMI SFCs | BMN LCAs & RELOC's | Hotchkis STB | HSW 150 shot | Lid | 42# Lucas | HPTuner Pro |
  1. Question: how can i remove this
    By robs98mysticZ in forum Showcar and Detailing
    Last Post: 07-07-2012, 09:19 PM
  2. Question: keep or remove? if so.. how?
    By saucycrossover1 in forum Appearance Section
    Last Post: 09-25-2010, 12:32 AM
  3. how do i remove pcm
    By jmatt07 in forum General Help
    Last Post: 03-17-2009, 11:32 AM
  4. how to remove gto from FRC's?
    By Frankthetank in forum Appearance Section
    Last Post: 10-26-2007, 01:15 PM
  5. remove eng from the top?
    By H8S2W8 in forum Internal Engine
    Last Post: 12-01-2006, 04:24 AM
