Results 1 to 13 of 13
    Aug 2006
    Peoria, IL/ Jacksonville, NC
    BLACK
    Pontiac Trans Am
    remove eng from the top?
    new to fbodys... but not to working on cars. just trying to find out if i can pull the block (heads,intake,etc removed) out of the car without dropping the cradle? I need to replace the entire motor but I dont have a lift to drop the cradle from under the car. any suggestions? thanks for the help.
    ~JOSH
    USMC Active Duty
    OEF~ Feb 04 to Sept 04
    OIF~ Aug 05 to Mar 06
    Quote Originally Posted by H8S2W8 View Post
    Me and another guy did it through the top once. Take the hood off as well. Its not easy, but can be done.
    Painted manta stripe
    i did it useing chain and a forklife... it was VERY difficult... took well over a hour to get it out...
    Blown, Stroked, & Sprayed
    Ed Blown Vert's Avatar
    Aug 1999
    No Where
    383 Procharged & N20 Vert
    I have down it twice from the top. Hood off and I would pull the intake off too.
    http://www.ls1.com/forums/attachment...8&d=1126930481
    Forged 383 | ATI D-1SC
    NX MAF Kit | 222/226 .585 115
    AS Stage II 6.0L FI Heads
    Tucson, AZ
    2002 Camaro SS
    Did you unbolt it from the tranny or did both come out together. I can't see from the pic. If you did unbolt the trans, did you just take the tranny out first?
    Aug 1999
    No Where
    Quote Originally Posted by enginjoe View Post
    I took the tranny out first becuase I have an auto and its long. Some didn't with a M6.
    Tucson, AZ
    2002 Camaro SS
    Thanks. I think that's what I'll do since I'm a pro at taking the tranny out and I don't think it would be easy to get out by just unbolting the engine (if I could even reach the bolts).
    2002 Camaro SS STS T67 turbo
    2003 SRT-4 some mods
    Alabama
    Take the tranny out, can leave bellhousing on and pull intake off. Also take hood off and she will come right out. I have done it three times in the past month. Couple hours of work and it will be done.
    Senior Member 440 rwhp trans am's Avatar
    Jun 2006
    houston, tx
    red ta orange gto
    97 trans am 06 gto
    yes take the tranny and intake off and yank it out! it only took me about 10min to pull it after i got it unbolted
    Tucson, AZ
    2002 Camaro SS
    Sweet. Leaving that bell housing on is going to save some time and knuckles.
    Northern Kentucky
    Mine came out with the hood on, motor unbolted at the bell housing. Engine hoist and chains, attached at opposite corners to bolts on the heads.
    Tucson, AZ
    2002 Camaro SS
    I just thought of something. What type of threads are those in the side of the heads for attaching the chains?
    texas
    2001 formula
    I just got done replacing the LS1 engine in my 2001 formula. I did a lot of research on which way to drop the engine out. I eventually took it out thru the bottom. I have never done a car like that but I found it to be real easy. Advantages to removing from the bottom are dont have to remove manifold and all wiring on engine dont need to be disconnected prior to removal. Just unplug main harness from computer and also connector plug from under dash board and a few other minor things. The cradle is held on with six bolts and unbolt both shock towers and steering joint and the brake lines and you are ready to drop engine. If you go out thru the top you must undo the radiator and fans anda/c condensor and thats not an easy job. I bought a motorcycle jace and positioned it between the oil pan and cradle and used my floor jack on the tranny oil pan. I used my engine hoist and used chains from the shock towers and hoisted up the car high enough to get the cradle to clear and rolled the engine and trannyout and then relowered the car down. Once you have the unit out everything is real easy to swap over. I was scared at first about this way of doing it but after it was all done I feel it was easier that going out thru the top. Good luck
  1. Question: how can i remove this
    By robs98mysticZ in forum Showcar and Detailing
    Last Post: 07-07-2012, 09:19 PM
  2. Question: keep or remove? if so.. how?
    By saucycrossover1 in forum Appearance Section
    Last Post: 09-25-2010, 12:32 AM
  3. Question: What all do i need to do to remove egr?
    By SteveCZ28 in forum External Engine
    Last Post: 01-05-2010, 04:55 PM
  4. how do i remove pcm
    By jmatt07 in forum General Help
    Last Post: 03-17-2009, 11:32 AM
  5. how to remove gto from FRC's?
    By Frankthetank in forum Appearance Section
    Last Post: 10-26-2007, 01:15 PM
