Results 1 to 16 of 16
Thread: how can i remove this
07-04-2012, 02:00 PM #1Member
- Mar 2011
- Waynesboro, Pa
Mystic Teal Metallic:320c- 1998 Camaro Z/28
not sure if this is the right thread to post this in but....when i bought my car it had what looked to be a gps 3m mount on the dash, yea the vinyl dash. anyways i removed the plastic mounting point but the 3m stayed on the dash. have been putting this off for fear of ripping, tearing, chunking, basically putting any flaw in the dash. if anyone knows what a safe way to remove this is please chime in. ive considered heating with a hairdryer then goo gone ect ect but i dont know if goo gone will discolor the dash or if i will be able to remove without damage
07-04-2012, 08:21 PM #2Senior Member
- Oct 2008
- Coral Springs, Fl
I think a heat gun/hair dryer would be the first step like you said. Maybe you could slip some fishing line under it to loosen it up off the dash
07-05-2012, 06:42 AM #3its short but its skinny.
- Oct 2009
- The Woodlands/spring/houston
pewter- 99 trans am
yea heat it up and see if itll slide around.....my radar detector mount heats up in the sun and loses origional postition...drives me nuts
07-05-2012, 07:58 AM #4Member
- Mar 2011
- Waynesboro, Pa
would a heat gun be too hot or start with a hairdryer and if that doesnt work enough bump to a heat gun on low and slowly increase heat until progress is made and i would have never thought of fishing line
07-05-2012, 10:27 AM #5Senior Member
- Oct 2008
- Coral Springs, Fl
Start low and see if the hair dryer worksNot sure how the goo gone would react to the dash
07-06-2012, 07:19 PM #6
Heating up and rolling it off would probably work good and maybe some rubbing alcohol to remove the last of the gooey stuff?
07-06-2012, 10:47 PM #7
heat gun should do the trick.....just dont get to close and take your time
07-07-2012, 12:32 AM #8Junior Member
- Jun 2011
- Calgary Alberta Canada
Bright Red- 1998 Camaro Z28
WD-40 use on any goo ....less harsh than alchohol
07-07-2012, 06:35 AM #9
07-07-2012, 07:35 AM #10
Heat gun would be too much for a vinyl dash imo. Hairdryer and as suggested, maybe a piece of nylon fishing line. WD40 should remove the adhesive without harming anything. Just be sure to wash the area with warm soapy water when finished and then hit it with a vinyl protectant.
07-07-2012, 08:01 AM #11Member
- Mar 2011
- Waynesboro, Pa
i just have a slight amount of sticky residue left. i parked in the hot sun this morning and then worked it with a plastic razorblade (lightly). turns out a finger nail is better than the razorblade lol. i just keep hitting it with vinyl cleaner to soften the foam, which is now all gone. now just gotta get the rest of the residue off. time to bust out the wd i guess
07-07-2012, 08:42 AM #12Member
- Mar 2011
- Waynesboro, Pa
so after plastic razorblade and more useful a fingernail of all things...dont mind the cracked dash pad
couldnt find wd40 so i gave armorall a shot sprayed the residue, let it sit for 5-10 mins. folded up paper towl and rubbed with medium pressure in a circular motion. and voila!!! then i had to clean the dash so there wasnt a super clean spot and then the rest of the dash haha
07-07-2012, 12:13 PM #13
Good work.
07-07-2012, 03:21 PM #14
Can't even tell it was there!
07-07-2012, 06:12 PM #15Member
- Mar 2011
- Waynesboro, Pa
thanks jeff!
edgar im pretty happy with how it turned out!
07-07-2012, 09:19 PM #16Senior Member
- Oct 2008
- Coral Springs, Fl
Nice work
Question: keep or remove? if so.. how?
By saucycrossover1 in forum Appearance SectionReplies: 15Last Post: 09-25-2010, 12:32 AM -
Question: What all do i need to do to remove egr?
By SteveCZ28 in forum External EngineReplies: 8Last Post: 01-05-2010, 04:55 PM -
how do i remove pcm
By jmatt07 in forum General HelpReplies: 3Last Post: 03-17-2009, 11:32 AM -
how to remove gto from FRC's?
By Frankthetank in forum Appearance SectionReplies: 5Last Post: 10-26-2007, 01:15 PM -
remove eng from the top?
By H8S2W8 in forum Internal EngineReplies: 12Last Post: 12-01-2006, 04:24 AM
