Thread: how do i remove pcm
03-17-2009, 07:20 AM #1Member
- Jun 2008
- ohio
black- 1998 Camaro SS
how do i remove pcm
doing h/c/i change and getting a mail order tune. im sure this is a dumb question but how do i get the pcm out. it looks like its bigger than the hole it has to come out of.
03-17-2009, 09:36 AM #2Simpsons Did it!!
- Mar 2007
- Minnesota
83 Z28 new project- 98 Formula WS7-sold:(
There's like two bolts that hold down that plastic thing it sits in. Take those out and the pcm is loose. I had to also get the plastic cowl loose by taking out the rivets. Use a pic or something like it to pry up on the center of the rivet, then the whole thing will pop put out of there. With that loose, you can wiggle the pcm out of there, it needs to be just right to get it out of there.
03-17-2009, 10:20 AM #3Impounded
- Oct 2007
- Beaver Dam KY
03-17-2009, 11:32 AM #4Senior Member
- Jul 2005
- Jacksonville, FL
Probably doesn't need to be said, but make sure the ignition is in the off position and the battery is disconnected.
Question: how can i remove this
By robs98mysticZ in forum Showcar and DetailingReplies: 15Last Post: 07-07-2012, 09:19 PM -
Question: keep or remove? if so.. how?
By saucycrossover1 in forum Appearance SectionReplies: 15Last Post: 09-25-2010, 12:32 AM -
Question: What all do i need to do to remove egr?
By SteveCZ28 in forum External EngineReplies: 8Last Post: 01-05-2010, 04:55 PM -
how to remove gto from FRC's?
By Frankthetank in forum Appearance SectionReplies: 5Last Post: 10-26-2007, 01:15 PM -
remove eng from the top?
By H8S2W8 in forum Internal EngineReplies: 12Last Post: 12-01-2006, 04:24 AM
