    Greene, Iowa
    99 Chevrolet Camaro Z-28
    What all do i need to do to remove egr?
    Quite simple as the title says. what do i need to do to remove all of my egr/air?? i know its simply remove the stuff, but how to i fill the hole behind the t.b? and will it throw a ses light? or how can i get that tuned out simply and cheap? thanks in advance guys
    Member jeffsWS-6's Avatar
    Winchester,CA
    BLACK
    2001 WS-6
    ws6 store sells a block off plate for the egrs and yes you will throw a code once its removed. if you send you pcm to frost he can delete that code. otherwise it will keep coming back if you keep erasing it with a hand held.
    Greene, Iowa
    wont frost charge me like 100 to delete the egr from the pcm?
    Winchester,CA
    BLACK
    2001 WS-6
    yes but you wont get the constant light. and he can give you around 10 hp just by tweeking the stock tune. if you ask me 100 bucks is good for 10 hp.
    Greene, Iowa
    well i guess ill have to get all the other stuff i want done first before i send out to frost
    Winchester,CA
    BLACK
    2001 WS-6
    as far as removing that stuff as long as you block them off , it wont hert the performance of the car, even though the SES light will be on. some people say you can burn up the O2 sensors faster but i didnt have any problems. and i drove my car for a month with it like that.good luck.
    you can plug the hole in the intake with a 1 3/8" expandable freeze plug. You can cut out and make your own block offs for the manifold or buy them...I know thunder racing carries them.
    There's also an egr timing adder table in the pcm that needs zero'd out or you'll start to see tip in knock retard.
    Another option is to go to installuniversity.com and follow their write up and just trim the egr tube back so it doesn't stick down into the airflow.
    Another vote for the $2 or $3 freeze plug for the intake. I have done it on a buddies car and its worked great.
    Coral Springs, Fl
    Sunset Orange Metalic
    Same here
    Got a 1 3/8" freeze plug and its been working great
    If you find a local performance shop around you they could probably tune it out for around $50. Could just get an LS6 intake if you wanna go all out.
    To remove air you can get blockoff plates or do what i did just get a piece of aluminum about 1/4" thick and cut out a plate with a jigsaw. Then use a gasket to seal it.
  1. Question: how can i remove this
    By robs98mysticZ in forum Showcar and Detailing
    Last Post: 07-07-2012, 09:19 PM
  2. Question: keep or remove? if so.. how?
    By saucycrossover1 in forum Appearance Section
    Last Post: 09-25-2010, 12:32 AM
  3. how do i remove pcm
    By jmatt07 in forum General Help
    Last Post: 03-17-2009, 11:32 AM
  4. how to remove gto from FRC's?
    By Frankthetank in forum Appearance Section
    Last Post: 10-26-2007, 01:15 PM
  5. remove eng from the top?
    By H8S2W8 in forum Internal Engine
    Last Post: 12-01-2006, 04:24 AM
