Results 1 to 13 of 13
    Member slpcamaro's Avatar
    sunnyvale
    98 ss camaro
    01 trans am over heating
    so my friend has an 01 trans am a4 ls1 and earlyer today he noticed it started over heating. it does it in the city like going down a block and on the freeway cruzing at 65mph.
    We are thinkin its his water pump or a thermostat.
    any other idea what can be causing this?? not sure where the thermostat is I looked in the same place that it's on my camaro not there.
    Canada eh
    99 TA
    Any leaks?
    could very well be the thermostat, it is located on the front of the engine towards the pass side, you have to buy the thermostat and the housing as a whole (still inexpensive)
    http://www.highperformancepontiac.co.../photo_12.html
    Member red99ws6's Avatar
    tazewell, tennessee
    1999 Trans Am WS-6
    why would they be in a different place than a camaro
    Canada eh
    99 TA
    Quote Originally Posted by red99ws6 View Post
    they shouldn't be...
    Feb 2006
    2002 WS6
    Is it fine at a stop? or do the temps start to drop? Cause if that is happening then the lower air dam has been damaged or ripped off, the black plastic thing that hand down just infront of the K member. It directs the air up to the rad, could also be that the passage way could be blocked as well.
    Feb 2006
    2002 WS6
    Quote Originally Posted by KyleLs1 View Post
    The differance between an LT1 and LS1.
    Canada eh
    99 TA
    Quote Originally Posted by Orcus79 View Post
    OP's car is a 98, still an LS1
    Feb 2006
    2002 WS6
    My bad need to get schooled on my history. *goes looking for the dunce cap*
    sunnyvale
    98 ss camaro
    sorry it's in the same place on my camaro. The difference is under my radiator cap a little ways down theres some type of sensor in my radiator but he doesn't have it on his I dont know if mine being a m6 and his a a4 would be something. The car over heats no matter what running or driving I was thinking either water pump or thermostat any way to check? I believe the waters pumps are designed to leak when they go bad but no leak.
    sunnyvale
    98 ss camaro
    he's looking at the slp thermostat is only $24 but no housing or the thermostat and housing for $39. what do you suggest if you think this is the problem
    LT1 Guy
    Va Beach
    Quicksilver
    03 Corvette Z06
    Quote Originally Posted by slpcamaro View Post
    Thats sensor you are refering to is the coolant level sensor. As for the over heating take a look at the radiator cap seal, and the coolant level. Start off as cheap and simple as you can.
    sunnyvale
    98 ss camaro
    Quote Originally Posted by 96slow6 View Post
    gotcha makes sense why doesn't his car have on that I can see and we topped the radiator off no luck still over heating and no sign of leaking.
    LT1 Guy
    Va Beach
    Quicksilver
    03 Corvette Z06
    I dont know man. Let me think on it. I do not know the LS1 cars that well. Try the stuff the other guys posted to. Check the coolant level in the over flow.
  1. Heating Oil
    By pajeff02 in forum Almost Anything Goes
    Last Post: 01-28-2011, 04:23 PM
  2. over heating
    By Krazydan in forum General Help
    Last Post: 07-10-2010, 04:59 PM
  3. Car over heating??
    By touch109 in forum External Engine
    Last Post: 08-19-2006, 08:31 PM
  4. Heating on an LT1
    By camarostripes96 in forum LT1
    Last Post: 08-07-2006, 04:02 AM
  5. over heating?
    By momsls1 in forum General Help
    Last Post: 02-19-2006, 07:32 PM
