Thread: over heating?
02-18-2006, 02:58 PM #1Member
- florida
over heating?
i saw that the temp was kinda getting high when i was driving the other day. the water pump iis fin cause ii can see the coolent moving but the fans come on but they seem like there spining slow. any one got any ideas? i know all the relays are working. can the high speed burn out in a fan and still have the low speed work?
is there anyway i can jump the relay and see if it will run on high speed?
02-18-2006, 11:18 PM #2
you can pick up a 160 degree thermostat if everything else checks out. Not sure about the fans. Never really looked at mine when they were on.
02-19-2006, 06:25 AM #3
If I remember right the high speed works when the A/C comes on.When you say the temperature was high what do you mean?The gauge isn't all that accurate in reality.These cars can run as high as 220 degrees on a normal basis.
02-19-2006, 09:28 AM #4Member
- florida
i mean high from what it normaly runs at. and the fans are slow as shit when the ac is on.
02-19-2006, 07:32 PM #5
The temperature gauge should run right at the 210 mark ,maybe a little below,maybe a little above,but never well above .When the fans come on-does the temperature drop alittle?Check your coolant level in the bottle when fully warmed up.
Heating Oil
By pajeff02 in forum Almost Anything GoesReplies: 30Last Post: 01-28-2011, 04:23 PM -
over heating
By Krazydan in forum General HelpReplies: 3Last Post: 07-10-2010, 04:59 PM -
01 trans am over heating
By slpcamaro in forum General HelpReplies: 12Last Post: 04-09-2008, 12:37 PM -
Car over heating??
By touch109 in forum External EngineReplies: 7Last Post: 08-19-2006, 08:31 PM -
Heating on an LT1
By camarostripes96 in forum LT1Replies: 10Last Post: 08-07-2006, 04:02 AM
