Results 1 to 11 of 11
    Import Killer camarostripes96's Avatar
    Aug 2006
    academy,tx
    1996 Trans am
    Exclamation Heating on an LT1
    I have an 96 Trans am LT1 6 speed, and i was just needing to know what temperature they ran at ? at first when i got the car i thought it was getting hot and then everyone is telling me thats what they run at. Can anyone tell me what they are supposed to run at?
    thanks
    Aug 2006
    NC
    mystic
    95 LS, yes it says LS
    If ther computer is stock, I think the fans don't even come on till 210 degrees.
    Oct 2001
    Colorado
    95 Z28
    The cars can regularly go to and over 210 degrees in hot weather or traffic. Optimal temps for power seem to be between 170-185. If you want to cool it off, a 160 thermostat and fan switch are invaluable.
    Aug 2006
    academy,tx
    1996 Trans am
    is the fan switch manual or automatic?
    Aug 2006
    NC
    mystic
    The fans are electric and turned on by the computer. Not sure about your ? hope that helps.
    Aug 2006
    academy,tx
    1996 Trans am
    ok thanks
    Aug 2006
    NC
    mystic
    Some places will do a small ECU tune on your car. It useually does your fan temps tire and gear changes and some do shift points for a small amount. Might check around your area for something like that.
    Aug 2006
    academy,tx
    1996 Trans am
    ok thanks
    Oct 2001
    Colorado
    95 Z28
    A manual fan switch lets you turn the fans on and off (on the high or low setting) whenever you need to, and still retain factory fan operation
    Aug 2006
    academy,tx
    1996 Trans am
    Ok I Would Really Like To Get My Computer Programmed To Make It Come On Earlier Rather Than Have To Constantly Look At The Gauges And Worry About Turning The Fans On.
    NC
    Thats normal for an OBD-2 car. The factory set those up to run much hotter than the OBD-1 cars. Mine runs about 175-180 in normal weather. In hot traffic it creeps up to 195-200
  1. Heating Oil
    By pajeff02 in forum Almost Anything Goes
    Last Post: 01-28-2011, 04:23 PM
  2. over heating
    By Krazydan in forum General Help
    Last Post: 07-10-2010, 04:59 PM
  3. 01 trans am over heating
    By slpcamaro in forum General Help
    Last Post: 04-09-2008, 12:37 PM
  4. Car over heating??
    By touch109 in forum External Engine
    Last Post: 08-19-2006, 08:31 PM
  5. over heating?
    By momsls1 in forum General Help
    Last Post: 02-19-2006, 07:32 PM
