Thread: Car over heating??
08-19-2006, 06:45 PM #1Junior Member
- Jun 2006
- NY
red- Chevy Camaro SS
Car over heating??
I was just drivng my car on the highway and had the A/c when i look down to see how much gas i have left i see that car is almost 260... I quickly turn off the A/c and it goes down to about 230.... It was about 90 outside and i was trying almost 30 mins... what can be wrong... i changed the coolant last year.. its never done this before.... I do have a xenon body kit
08-19-2006, 07:00 PM #2Senior Member
- Aug 2003
- Honolulu HI
Pewter- all bore 370 Trans Am
sometimes the guages act funny. to know for sure, you should get it scanned with efi or hpt. I kno wyou did the coolant change last year, but have you tired bleeding it?
08-19-2006, 07:43 PM #3Junior Member
- Jun 2006
- NY
i didnt use something else to check the temp.. but i could feel it hot.. i even noticed the a/c not beeing as cold ... coolant was checked and was fine..
08-19-2006, 08:08 PM #4Likes twisty roads
- May 2006
- England but from TX
Light Pewter Metallic- 2K Camaro Z28
First off what year and mileage of the car are we dealing here?
Could be alot of things right now if you don't get down on specifics, bud.
08-19-2006, 08:08 PM #5Senior Member
- Aug 2003
- Honolulu HI
does it still have plenty of coolant?
08-19-2006, 08:14 PM #6Junior Member
- Jun 2006
- NY
car has enough coolant and has about 52k on it...
02 SS A4 35th Anniv Edition; Center mounted SLP Loud Mouth, SLP Blackwing intake, SLP bellows, Spohn chrome moly LCA, SLP eibach/bilstein combo, J&M Sub-frame, poly tranny mount, xenon bodykit .....
http://www.cardomain.com/ride/2133819/
08-19-2006, 08:26 PM #7Likes twisty roads
- May 2006
Is your fans coming on? Get someone pull you an accurate engine temp. (scanner/HPtuner/LS1edit, etc)The gauge in the car is pretty much a dummy gauge.
08-19-2006, 08:31 PM #8Senior Member
- Aug 2003
- Honolulu HI
run it while its warm and see if the fans are coming on. that could be a start. check the hoses and make sure you feel the coolant passing thorugh. basically, ensure eveything mechanical is up to par then go from there.
Heating Oil
By pajeff02 in forum Almost Anything GoesReplies: 30Last Post: 01-28-2011, 04:23 PM -
over heating
By Krazydan in forum General HelpReplies: 3Last Post: 07-10-2010, 04:59 PM -
01 trans am over heating
By slpcamaro in forum General HelpReplies: 12Last Post: 04-09-2008, 12:37 PM -
Heating on an LT1
By camarostripes96 in forum LT1Replies: 10Last Post: 08-07-2006, 04:02 AM -
over heating?
By momsls1 in forum General HelpReplies: 4Last Post: 02-19-2006, 07:32 PM
