Thread: car wont start need help
04-05-2008, 03:41 PM #1Junior Member
- Feb 2008
- meida,pa
red- 1994 chevrolet camaro z28
i had a question for u guys if you could help me i appreciate it. recently my car was running like crap and bogging down and it had no power so i took my spark plug wires out and they were melted from the headers. so i decided to change them and the plugs and when i was finished i went to start it and it cranked over but it didnt start. so my friend told me its probably a bad coil and i just got done replacing it 20 mins ago and it still cranks but wont start i need big help
04-07-2008, 05:39 AM #2LT1 Guy
- Nov 2006
- Va Beach
Quicksilver- 03 Corvette Z06
Make sure you have the wires in the right spots.
04-07-2008, 02:37 PM #3Junior Member
- Feb 2008
- meida,pa
04-07-2008, 07:18 PM #4
ignition control module may have been shot....the little rectangular chip looking thing by ur coil, take it to the auto store and they should be able to get it tested for free....that may be ur problem
04-07-2008, 07:39 PM #5
Sound like the ICM is bad. It just cranks up but won't start up? It has happen to me.
1996 Z28 LT-1 (with basic bolt-on)
04-07-2008, 07:54 PM #6Junior Member
- Feb 2008
- meida,pa
04-07-2008, 10:18 PM #7Junior Member
- PA
hmmm,
1 wire at a time...well you would know if you put a fitted set on or universal really by what slack you had.
Real easy to test them, I know autozone does.
04-12-2008, 10:51 AM #8
i would verify the wires are connected to the right cylinders according to the book. And then read the codes in the ecm if you have a way to do that. Otherwise, you're throwing darts in the dark. Also make sure your coil is plugged in and has power. (coil or spark thingy)
04-13-2008, 07:28 PM #9Junior Member
- Feb 2008
- meida,pa
yea i found the problem the coil wasnt getting any power so i had to trace it all the way to the battery and i found that these two wires werent connected i think my friend screwed it up but i connected them and it started right up i almost gone through a set of tires already leaving burnouts everywhere
Help: car wont start and now gauges wont work!
By AB'sLs1 in forum General HelpReplies: 52Last Post: 04-20-2013, 08:54 PM -
Z71 wont start
By duranws6 in forum General HelpReplies: 4Last Post: 01-09-2013, 07:49 PM -
LT1 wont start
By Bad Co. in forum General HelpReplies: 8Last Post: 11-18-2010, 07:23 AM -
LT1 wont start
By Bad Co. in forum LT1Replies: 0Last Post: 11-16-2010, 05:32 PM -
car wont start
By redss2000 in forum General HelpReplies: 12Last Post: 06-20-2008, 01:06 PM
